Question about Alpine Car Audio & Video
Where can i get a magazine cartridge for a Alpine compact disc changer 5952Z and how much?
  • 44 Answers
SOURCE: Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Posted on Jan 09, 2008
Eagleeyes
  • 199 Answers
SOURCE: factory installed Alpine 6 CD Changer- cd magazine (for 1998 BMW 528i E39)
Hi , seen lots of these.
whats happend is the Tray that the disc sits in has jammed halfway in.
in most cases giving the mag a swift tap (hard tap) with the haddle of a screw driver , while pushing the eject button normally is just enough to dislodge the mag.
otherwise its a repair job.
were do you live Alison?
Regards
Mark
www.blueice-electronics.co.uk
Posted on Jun 23, 2008
landsend
  • 1066 Answers
SOURCE: have alpine chm s620 ,error message say no disc magazine is loade
have you tried a different magazine.  Could this one be warped?
Posted on Apr 03, 2009
welcomejee
  • 10594 Answers
SOURCE: where do i get the cartridge/magazine for sony cdx t67
Part number for CDX-T67, CDX-T68 cartridge is A3315428D and its available in Sony Accessories Store for $51
Posted on Nov 07, 2009
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
Cartride won't eject
The magazine may not be able to eject because a CD is stuck and not completely seated inside.
Mar 26, 2014 | JVC Xc-m75 Kenwood 6 Compact Disc Magazine...
Need to remove discs from uninstalled Alpine 5952Z
download your instsr. manual, and see the section troubleshooting go www.retrevo.com or www.manualslib.com
GOD BLESS YOU
Nov 03, 2013 | Alpine 5952z 6 Disc Cd Changer Rare...
Cd changer magazine does not eject
Feb 09, 2010 | Alpine CHM-S630 6-Disc CD Changer
Looking for magazine for alpine chm 5620
The Alpine CHA- and CHM- changers all use the same magazine. You can search eBay or google shopping for "Alpine CHM Magazine" and you should see a variety of sellers, with prices from 25ish for used ones up to 40ish for new ones.
Feb 05, 2010 | Alpine Car Audio & Video
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
Display read "disc error" then "no magazine"
Most likely there is a CD jammed in transit between the player mechanism and the magazine. This is a common problem. You will have to remove the unit and disassemble it sufficiently to get the CD back in the magazine and, in turn, allow the magazine to be removed.
Jan 28, 2018 | Alpine Car Audio & Video
Car Audio & Video Logo
101 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
