Question about Huffy Planes 14" Bike - 14"
I cany get the plastic cap off the end of stem for the handlebars
  • 27 Answers
If you're talking about the handgrips, I've soaked them in hot water and then taken them off. The hot water softens them and causes them to swell a little. It still takes a bit of persuasion so you might want to have a strong person help.
I've also used a knife to cut them off but be careful!
Posted on Oct 15, 2015
Handlebar adjustment
Threadless stems limit what you can do with height.
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Jul 09, 2011 | Apollo Evolution XC
Can I raise the handlebars? I can raise the saddle but the handlebars seem fixed?
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Apr 11, 2011 | Fuji Nevada 50 Mountain Bike Performance...
How do i raise the handlebars on the schwinn graft mountain bike? Do i need a riser?
Probably. Getting Riser Bars or a riser stem or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Detailed advice...
Apr 10, 2011 | Cycling
How do you raise the handlebars
There's a ring nut between the stem of the handlebars (The stem is the vertical part of the handlebars) and the frame of the bike where the handlebars connect into the frame. The handlebar stem goes down through the ring nut into the frame.
Loosen the ring nut and you'll be able to raise the handlebars. There's a mark on the handlebar stem which indicates the highest point that the handlebars can be raised to. If you raise it above this there won't be enough of it in the frame and this can cause the stem to break when pressure comes on it. Also when tightening the ring nut up again make sure you have the handlebars and front wheel lined up.
Jan 16, 2011 | Cycling
How do u raise handlebar heigth on f400 bycycle
There are only a few ways to raise the height of your handlebars (the actual grip portion you hold onto)
1) - Raise the stem. How this is done is determined by what type of stem you have.
A. If the stem is inserted via a shaft into the frame, then you must loosen the bolt in the center of the shaft to raise and lower the stem. This has limitations (a line on the end of the inserted portion of stem) you can not go past the max insertion line. If you need it higher, then you need a new stem that allows for more height.
B. If the stem clamps around the fork steerer, then you can only raise the stem as high as the end of the fork. In some cases you can invert the stem for greater height. If you need greater height, then you will have to replace the stem with one that has greater angle.
2) - Replace the handlebars with ones that place the grips higher relative to where the bars clamp to the stem.
In all cases this would be a good project to take into your local bike shop, show them what you have and ask them for the best solution to raising your handlebars.
Things to keep in mind: When you raise the handlebars you increase the distance from the controls to the brakes and derailleurs. If you want to raise past a certain point you will need to replace your cables and housings as they will need to be longer.
DO NOT RAISE ANYTHING ABOVE THE LIMIT LINES: This will cause the bike to be unsafe and could fail causing a serious injury or worse.
Dec 11, 2010 | Cycling
I would like to raise the handlebars. I have loosened the stem wedge nut and the handle bars will not budge. I've tried everything almost to the point of losing the ball bearings in the steering shaft. Are...
Hey joe - Sounds like you have a classic stuck stem. Here are a couple things to try.
1 - Loosen the stem through the top bolt so the wedge is loose, but not removed. The give the top of the stem a good hit or two with a plastic mallet. That should break the bond between the steerer and the stem. If that does not work...
2 - Use liquid Wrench and drip around the stem so it seeps in-between the stem and steerer. Let sit a while then try the plastic mallet again.
sometimes you will need to work the stem back and forth a bit by using the handlebars as leverage and bracing the front wheel between your knees.
If neither of these get your stem loose, then it's time to take into a bike shop.
BTW - stems have a maximum insertion/ extension. There is a line of max extenstion that should be on the shaft when you get it removed. If you discover that the stem will not raise your handlebars enough, then you can get a replacement stem with a higher shaft and greater angle to lift the bars up.
Nov 11, 2010 | Cycling
Raising the handlebars
If your bike is older it might have a quill stem.To raise this you have to undo the allen key headed bolt situated where the bar & stem attach to the bike.It is often obscured by a plastic plug to prevent water rusting the bolt head.If this doesn't go high enough an adjustable quill stem must be fitted.
If you have the modern design of stem(A-head)you will have to replace the stem with an adjustable type which can be set upto 60 degrees.
Sep 29, 2009 | Cycling
Can I raise the handlebars on my Marin hybrid bike and how do I do it?
Most likely you have a threadless headset on your Marin which means you can not raise the handlebars without replacing the stem or handlebars themselves. In addition, many times you will also have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you do not have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
So if you have a threaded stem, simply loosen the allen head or nut on the top of the stem and raise the stem up. Make sure you do not go above the max line and that you are still able to turn the handlebars freely.
Hope this helps. If you need any more help you can connect me at elijah@starbikesfl.com. Thank you
Jun 27, 2009 | Cycling
Can't tighten the handlebar stem.
hi lynduck,
are you using a threadless steam or a threaded one?
like this one in the picture.
http://www.sheldonbrown.com/images/headset-threadless.jpg
if so, spacers should be on the right spot and the pinch botls should be tights. top cap should not be moveable and this will make sure your front end turns lightly. apply light axle grease to make it smooth.
regards,
voodoo
Apr 19, 2009 | Cycling
Bicycle handlebars move seperatly from the wheel
My guess is that you are using an older, "quill" stem, which is both the STEM (the extension that the handle bars attach to) and the friction bolt that tightens the stem into the STEERING TUBE
Anyway, what I think has happened is that the quill is either not tightened or (because you said you tightened everything) the angled nut at the end of the quill isn't aligned properly and is tightening.
HERE is a great diagram of the quill stem. What I think you'll need to do is:
1 ) IF you have already tightened the bolt at the top of the stem (usually under a little plastic cap, like the one at the top left of the stem in the diagram). Then Untighten it and if you can pull it out make sure that the angled nut (shown at the bottom) is resting properly against the angled shaft of the quill (the vertical part of the stem). As you can see these will spread apart as you tighten the bolt, making them wider and holding them in the steering tube. The idea is to realign the angled nut so it can properly contact the shaft and spread.
2) if you haven't tightened this bolt (maybe because it's hidden), try tightening it a small amount and see if that changes anything.
__________________________
This was all written assuming your bike is not using the newer "threadless" setup, which would probably have been fixed if you tightened down the stem (PICTURE OF THREADLESS STEM)
Sep 27, 2008 | Sport & Outdoor - Others
Huffy Planes 14" Bike - 14" Logo
984 people viewed this question
Top Huffy Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Huffy Craft and Hobby Expert? Answer questions, earn points and help others
