Question about Pool & Spa
How do I drain spa? - Pool & Spa
  • 1,631 Answers
Some spa manufacturers, include a small half inch or three-quarter inch PVC flex pipe as a drain line that is located somewhere within the equipment bay of the cabinet.
Others extend that drain line to the actual wood or plastic skirting with a special knob or cap Located at the bottom corner of the cabinet, exterior side.
and others, such as Sundance spas, actually have a full one and a half inch pipe with a slice valve, or guillotine valve some call them with a threaded plug, Which will drain the tub much more quickly.
if you have a none of these, then you can either siphon with a hose, or use a submersible pump.
Posted on Mar 31, 2015
How to deflate and store
DRAINING THE SPA:
1. Unplug power pack from electrical receptacle before draining spa.
2. Put the rubber plug into the outlet in the inner wall of the spa.
3. Open the outlet in the outer wall of the spa. Screw one end of inflation hose into it.
4. Remove the rubber plug from the outlet in the inner wall of the spa.This will allow water to flow out of the spa. 5.When water is completely drained, press BUBBLE and run for 2-3 minutes to drain the water in the air pipeline. 6.When drainage is finished, remove the inflation hose and replace cap on outside of spa. Store rubber plug for future use.
SPA STORAGE
Make sure all water is drained from the spa and control box.This is essential to extend the life of the spa.We recommend the use of a wet/dry vacuum to blow out or suck up water from the spa pipes and pump lines. Remove the filter cartridge. It is recommended you store the spa in its original package in a warm, dry place.
Note: Plastic becomes brittle and susceptible to breakage when exposed to subzero temperatures. Freezing can severely damage the spa. Improper winterization of your spa may void your warranty.
http://img1.wfrcdn.com/docresources/17478/11/119999.pdf
Aug 13, 2014 | Therapure Four Person Inflatable Round Hot...
How to drain the spa
if pool spa combo put in service and switch right side button to spa drain or turn the actuator for the to spa and return to pool it should drain then put back for operation
Feb 18, 2014 | Jandy Pool & Spa
How to drain Vita Powerworks 504 spa?
Typically each spa will have one drain hose down with a valve close to the control box behind the spa skirting.
Rod
US Parts Center
888-521-6183
Feb 15, 2013 | Pool & Spa
Is there a better way of draining the spa,we have the manual and it refers to quick drain but there is no information anywhere in the manual regarding this or any other way of draining the spa.We are using...
Behind one of your access panels there is a pvc tube that has a square end on it that would the place to drain unscrew that plug and let er rip. Good Luck....
Apr 19, 2011 | Garden
How do I drain my spa?
is this built in spa (integrated with pool) or stand alone above ground spa? If it's above ground, you should have a drain plug along the bottom, possible behind a control panel. If it's an integrated spa, then depends on the plumbing. You may be able to just change a couple valves and drain into pool. Give me a little more info and I can help
Sep 12, 2010 | Flotec Pool & Spa
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa draining into pool
check should be on spa return line from filter or heater. its 1 1/2 or 2 inch pvc
Jul 13, 2009 | Jandy LAARS VALVE, PRESSURE RELIEF 75PSI...
Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Feb 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Spa drains when turned on
The problem is in your plumbing. Someone put a valve in an incorrect position. I would have to see a picture of your plumbing but if you can follow the flow of water. When you put it in spa mode, look at which valves turn and which ports open up. If it is doing anything other then sucking water from the spa and returning it only to the spa, then that is why it is draining. Again it would be great if you had a picture. What I have seen before is somebody plumbing in the pipe for a pool cleaner after the valve that send water to the spa. This would result in water from the spa slowly draining out of the pool sweep line. Good luck.
Jan 26, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
90 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
