Question about Pool & Spa
How to replace a soundbar on a Pacer entertainment center?
I bought a pacer 70 media w/soundbar and it does not work.
  • Sandra Pearson
    Sandra Pearson Mar 27, 2015
    model #26mm4s9626hb157
  • 366 Answers
SOURCE: My new Pacer is sucking but doesn't move around
check for debris inside the diaphragm. also check to see if the diaphragm is distorted, the sides of the **** should be parallel and should not have a huge gap or hole. You can check it by unthreading the stem just under the "steering" wheel, then push downward on the white tube and it should come out of bottom of the unit, the diaphragm will be connected to the white tube. Inspect and replace the diaphragm if needed.
Posted on Sep 21, 2009
  • 106 Answers
SOURCE: My pacer pool cleaner doesnot want to work , i put
Sounds like diaphragm is ripped. Replace
Posted on Jan 14, 2010
  • 106 Answers
SOURCE: Baracuda Pacer does not work. does not do
Replace diaphragm
Testimonial: "It is winter here now so I cant actually go test it..but in the summer the suction was minimal and it would start to vibrate a little and then stop."
  • 106 Answers
SOURCE: zodiac pacer
  • 990 Answers
SOURCE: Barracuda Pacer comes right up the side and above
You just need to slow the cleaner down and dirvert some suction away from it. It should never really come anymore than 1/3 the way up the wall.
Posted on Mar 29, 2010
Testimonial: "Thanks so much will give that a try"
How to adjust suction in a barracuda pacer
there is a flow meter for use with these units to ensure proper flow rate. if this tests in range, make sure there are no obstructions in the hose or cleaner. if there is still a problem, it might be time to change the diaphragm in the cleaner
Jun 18, 2014 | Zodiac Pacer Pool Cleaner
How can i oiling my kettler pacer belt ?
you dont oil it, you have to put treadmill wax on it, and you just put it under the belt on top of the deck at the front and the back
Apr 25, 2014 | Kettler treadmill Pacer
Where is main fuse amc pacer
AMC Pacer uses a Ford style electrical system which employs fusible links at the starter solenoid to distribute the battery power.
Apr 18, 2014 | 1975 AMC Pacer
I cannot adjust th speed on my york pacer 3100, it just goes very fast.
I'd suspect you need a new adjustment cable and/or the winder is broken. The latter happened to my York 2500 Pacer and I replaced the cable & handle with a bike gear change mechanism.
Mar 18, 2014 | York Exercise & Fitness
What's a pacer function?
This pacer function is used to set or regulate the rate of timing. It sounds an electronic tone at the selected rate for maintaining the pace of the activity in beats per minute. You can increase or decrease the rate in increments of 5 beats per minute. For example spinning on a stationary bike at 55 cycles per minute you would set the pacer at 55 beats per minute.
Aug 02, 2012 | Exercise & Fitness
Pool cleaner working very eratic , stop /starts
you probably need to replace the diaphragm, unthread the nut directly beneath the wagon wheel, press the white tube downward and inspect the rubber diaphragm for damage or deformity. this is the most common problem with the Zodiac Pacer.
Apr 07, 2010 | Zodiac Pacer Pool Cleaner
Zodiac pacer
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
Pool & Spa Logo
56 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
