Question about Cell Phones
How long after you do a factory reset does the screen come back on
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Usually once it is done.
Posted on Mar 27, 2015
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
How to reset my Motorola blur
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. Keep in mind, when using this feature; everything is deleted. Nothing stored on the MicroSD will be affected. Your information is automatically backed up to the MOTOBLUR server. Your information will be restored when you login with your user name and a password.
Factory Data Reset
  1. From the screen of your phone, open the Applications Tray. (circle located in the middle at the right of the display screen) Or press the Menu button on the left from your screen.
  2. Tap Settings
  3. Scroll down and tap Privacy
  4. Tap Factory Data Reset
  5. Tap Reset Phone
If you are unable to navigate through the menu to perform a factory data reset, you can follow the steps outlined below:
  1. Power off the phone, press and hold volume down button, press power button.
  2. Wait for the "triangle ! / Android" screen then release the volume down button
  3. Tap lower right-hand corner of Touch Screen
  4. Navigate on-screen menu to select "Wipe" (data/factory reset) and Press OK
  5. Navigate on-screen menu to select "Reboot System Now" and Press OK
  6. Wait for device to reboot
Apr 22, 2016 | Motorola Cell Phones
How to reset a factory fasttouch 7inch tablet
Hard reset or factory wipe is a method of formatting any Android device ( tablet or mobile). By doing hard reset all the apps and files that are installed or created by the user will deleted. Even the memory card will get formatted. So before going for hard reset or factory swipe, it is suggested to remove the memory card if you do not want data to be erased
For simple factory reset the process is follows:
Sponsored
  • Goto settings -> Back & reset -> factory data reset
After factory reset, only pre installed apps and files that came with the device will remain on it.
Feb 19, 2015 | Android 7 inch Tablet
Reboot my galaxys from black screen
Run a Hardware Factory Reset A hardware factory reset should be used as a last resort to fix a GS4 . The process will delete all stored information on the GS4 and return the device to its factory configuration; you won't be able to back up your data if you're getting the BSOD. Prepare the phone for the hardware factory reset process by performing a battery reset and pulling out the memory card. You can remove the back panel by pulling on the indentation near the power button. You can leave the SIM card in the device. After you've closed the device, plug it into the charger to avoid losing power during the reset process. To initiate the recovery menu, boot the GS4 by holding the "Volume Up," "Home" and "Power" keys. On the "Recovery" menu, use the volume keys to select "Wipe Data/Factory Reset." Then press the "Power" key to initiate the hardware factory reset.
Jan 03, 2015 | Samsung Galaxy Cell Phones
Netflix com
Performing a factory reset erases all of your settings and account information and restores your
1 Press home to go to the Home screen. 2 Highlight settings , and then press select to display the Settings screen.
3 Highlight factory reset, and then press select .
4 To continue with the reset, select factory reset. To cancel the reset, select back.
  • 5 When prompted, highlight yes to confirm that you want to reset your player, and then press
    select
Aug 21, 2014 | Roku Televison & Video
How can I fix a tv that has been reset to factory reset
Try resetting it again, resetting it should bring it back to the way you received it from the store. Unplug it first, then plug it back in, then try the factory reset.
Jun 08, 2014 | Audio Players & Recorders
How to format HTC WILDFIRE A33333
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
The most convenient way to do a factory reset is via the phone settings.
From the Home screen, press MENU, then tap Settings.
Scroll down the screen, and then tap Privacy > Factory data reset.
On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons:
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 25, 2011 | HTC Computers & Internet
My htc hd2 refuse to respond to my screen password, can you help me to do factory reset
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
By the way, do remember to backup your data first before hard reset
Feb 12, 2011 | Cell Phones
Touch Screen not responding
KIng LeO>> Try re-calibrating the screen, settings>screen> then select "Align Screen". If after you do that, it still doesn't work, try a factory reset.
neldie>> Do a factory reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
May 11, 2008 | T-Mobile Wing™ Smartphone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
