Model # 358-351701. 2.3 cu.in. 2cy.
SOURCE: chainsaw cuts out a few seconds running
hi frado
check the fuel lines,make adjustment to the carb,set the T ,check the fuel filter.Inside the carb,at the fuel pump side there is a screen,carefully clean it.Hope theese help.
regards savumihai71
SOURCE: runs for a few seconds then stops
there are two screws on the carburator one is for air other for gas .that need ajusment
SOURCE: Poulan 335 chainsaw starts easily and then stalls
1. You will first want to check your fuel lines for cracks/breaks.
2. If they are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure that the small screen in carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Check the gasket and diaphragm for breaksor wear. (NOTE): If your carburetor guts, (Carb. Kit), are more than 3 or 4 years old, you might want to replace them while you have it apart.
If you need further assistance, just let me know.
Jim
SOURCE: stalling chainsaw stihl ms310
One more thing to try hold her on her side and loosten the fuel cap a little. A plugged vent may also cause your problem. HTH
Lou
SOURCE: while cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
