Question about Craftsman Garden
Do I have a kill switch on my brand new craftsman 1000 31 riding mower ? If so where is it? An where is my starter motor and wires located at in front of mower?
My daughter ran over a metal stake in yard moving our brand new craftsman rider it won't turn the key won't that is and of course it won't start. The blade was up as she was moving it not mowing but she was going fast and it died instantly and won't start.
    Problem Solver:
  • 39 Answers
There is a switch under the seat of most lawn tractor stand up the tractor should stop, or turn off the key.
Posted on Mar 27, 2015
Replacement starter motor says remove band and rectifier from old starter. There is no band and rectifier on starter.Riding mower mod # 917.273370
Craftsman (american yard products) use alot of same parts for craftsman, husqvarna, poulan, and other brands if it doesnt have those parts on it you should be able to install starter as it is and be good to go.
Jun 29, 2015 | Craftsman Garden
I have a 27hp Kohler 54 in cut Craftsman ryder and the seat switch plug has been removed. I just have 3 wires. How do I wire this to a new seat switch. It is a grey 4 prong switch.
Go to
http://www.searspartsdirect.com/
Find the model number on your mower and enter it on the sears site. You should find a schematic there along with parts lists and diagrams,
My guess is that one of the three wires is connected to ground a second to ignition to kill the engine if you are off seat and the third to the starting relay to allow the starter to work if you are on the seat.
On the new plug two of the pins will probably be connected together. (The Ground)
Sep 29, 2014 | Craftsman Garden
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
INstalled new battery on Craftsman Riding mower. Now the motor wont start or even turn over.
You may have shorted out one of the wires going into the battery, blowing a fuse, or damaging the starter or the starter solenoid.
Mar 30, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Craftsman lawn tractor turns over but won't start
i would check the switch on the brake/clutch it has 2 switches built into one jump it with a paper clip to test it
Jul 31, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
We can't get a spark
The safety features on the riding lawnmowers can be hard to troubleshoot.
1.The starter should NOT operate when blades are engaged.
2.Spark will not occur without a rider ON the seat with the blades engaged,
3.Spark will function with the parking brake on (on some models)
Theirs two wires coming out from under the engine top cover,(for a Briggs)
One is for charging and the other is the kill switch.
If you remove the kill switch wire then attempt to start and the magneto is good
you will have spark.
DO NOT use mower without the safety functions connected.
If you have spark with the kill wire removed then the wiring and /or switches are faulty
Make sure the plug is against the ground or it will not spark.
We can go from here.
Good Luck
Jan 12, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding mower stalled out while riding will not start
It sounds like either the seat switch went bad or one of the other safty switches failed easiest way to test this is to dis-connect all wires to the motor, run a jumper form the positive post of the battery to the switch side of the stater solonoid to see if the motor turns over with everything else dis-connected if it starts start connecting wires one at a time until you get to the one tat causes the motor to quit then you have the problem circuit. It sounds to me like you either have a bad safty switch, bad key switch, bad Ground, or a faulty starter solonoid or maybe even a defective battery. Hope this helps Don
Nov 09, 2009 | Craftsman Garden
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Won't start after killing the motor
May need more info. Check for a seat switch to have came unpluged (wiring) this is a safty thing. You have to have your foot on the brake as you sit in the seat to get it to crank. repost if you need more help.
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
82 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
