Question about GPS
My teletrac gps finds postcodes but won't set route !!! Do I need a micro sd Cardin it
5 Suggested Answers
SOURCE: GPS 439 IGO route 66 -Car GPS can not find navigation not working
my navigon gps series 2100 has a problem with calculating the route and showing the turn - by - turn list.
Posted on Aug 19, 2009
  • 59 Answers
SOURCE: Micro sd card not showing up on the gps
Have you got GB Discoverer on the card? The map should appear on the Map Information list in the Setup > Map area. Double check the placement of the map card. Also, in case you have not found it yet, there's wealth of information on the Oregon Wiki here: garminoregon.wikispaces.com
Posted on Nov 04, 2009
  • 120 Answers
SOURCE: My new (purchased yesterday) TomTom750GO restarts
Bring it back, its a dud.
Posted on Sep 08, 2010
  • 1514 Answers
SOURCE: no detailed maps found that support routing.need
The solution to the "No detailed maps that support routing" problem can be found at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
To set up a map on the micro SD card you can follow the instructions on http://www.fixya.com/support/r5628920-update_garmin_satnav_maps Don't download directly to the micro SD card as it won't be recognised by your satnav. Download to the computer and install from the computer to the card as described at the above link.
Posted on Apr 11, 2011
No detailed maps found that support routing.need to download software on to micro sd card for garmin nuvi 205
Apr 11, 2011 | Garmin nuvi 205W GPS Receiver
Tt postcode probs
you need to update your post code database. i had the same problem whilst installing on a no PPC. download the tomtom home package, plug in and tell it to update. it shuould i believe update you post codes for free. if not its a paid for thing unless you take the dodgy route lol
Jul 11, 2009 | Tomtom GO GPS Receiver
I have a sat nav which I beleive uses tomtom 5 or 6 software. The unit which connects to any in car screen (so it is basically a stand alone box) has an SD card which I have programed with extra voices...
There are few things here to consider.
1) the 4 digit postcode is related to say Australia, you are using the basic fronte end of a set of maps designed for a country with 4 digits but have modified some poi's that should be in a 6 digit environment
The size of the card is beyond the ability of the unit to read, so you get errors. Use a smaller capacity card and try again.
If your GPS alllows music and photo storage, use a separarety card for these and put the orginal capacity card back for the maps
You have also programed in a starting point location.. your home. All GPS gave this feature, remove it and leave blank it will say always start from Sydney CBD.by default, unless programmed otherwise to your address.
If it continually defaults to a non standard ( your address) bthen when it is savin the information the personal info file is corrupt.
As you have fiddled with the software it will bew hard for any tech to sort out your problem.
I have this all the time on our own brand of GPS, where people change voices, put in POI's written and converted from other models or even brands and somehow corrupt the basic files.
If you have a card reader ( i am sure you do) put the card in and type part of your address in SEARCH and see which file it appears in (.data) (.txt) delete it and recreate it then try again.
Hope that helps
Jun 21, 2009 | Tomtom Navigator Bluetooth GPS Receiver
Jun 18, 2009 | GPS
We have a problem putting in names and addresses.
All tomtoms are more or less the same. You tap the screen to make selections.
Switch on , let it boot up / Tap the screen / Then tap " Navigate to" / then tap "address" / Then tap either "City centre" or " Street and House Number , or Postcode " ( you select one of these by tapping screen ) . Lets say you just tapped "Postcode" . A keypad will appear on the screen for you to enter a postcode. NOW, enter the postcode ... as you enter the postcode , streetnames will appear and you can either continue to enter the postcode OR you can choose one of the street names that appear. Once you have done this , the tomtom will ask you to select a "house number" . if you don't know the number then just 'try' selecting number 1 . Once you have done this , select "Done" and the tomtom will switch for that screen to the "route calculation screen" . if you now tap the screen once more your tomtom will start giving you direction both visual and audible , to your destination . ( you must begin to move before it will start ) . ....................... Once you have completed the journey , you can now cancel the navigation by once again tapping the screen , then use the "right arrow icon" to move through the menue screens. When you see an icon with a RED CROSS through it , and underneath it says " clear route" , select that by tapping and the route / navigation will be cleared. ... Good luck , hope this helps.
Nov 27, 2008 | Tomtom One XL GPS Receiver
General confusion with plethora of maps etc
If you have a copy of mapsource read the help file
"Transferring and saving mapsource data"
if the data will not on your (micro)SD card use a bigger one
Dec 25, 2007 | Garmin GPSMAP 60CSx GPS Receiver
TomTom 510 postcode
The postcode information has to be in a folder named ZIP. This can be either on the SD card or as a subfolder of the NAvigator folder in Program Files on your device
May 09, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
83 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
