Question about Home Security
?How do I reset to factory settings on Honeywell HRHD16C320
  • 3,957 Answers
If you do not have the manual, you can download from here: http://www.manualslib.com/download/811165/Honeywell-Hrhd4Plus.html
They state there is a reset switch on the unit, but does not show any pictures or describe where it is.
Think I just found your answer: http://www.cunninghamsecurity.com/wp-content/uploads/resources/HRXD-UserManual.pdf
Pinhole next to a USB port on this unit. Paperclip to reset (pg 30). If not same unit. look around for a pinhole switch location.
Hope this helps.
Posted on Mar 27, 2015
    Top Expert:
  • 1,144 Answers
"The DVR has a Factory Reset switch to the right of the USB port. This switch will only
be used on the rare occasions that you want to return all the settings to the original
factory settings."
(See User Guide, page 15):
http://www.beacon-ni.co.uk/wp-content/uploads//2011/11/HRHD4-9-16-UserGuide.pdf
My Honeywell needs to be reprogrammed. It will not let me set it to a temperature.
Try to reset unit to factory defaults. If it cannot be done, then the unit, if it continues to not work properly, is toast.
Sep 19, 2017 | Honeywell Heating & Cooling
How do I factory reset a Honeywell HRGX45 DVR
You. Will have to go online to do a reset also check for a jumper take the battery out and reset inside
Aug 14, 2016 | Honeywell Home Security
How to reset Honeywell UDC2500
The procedure to restore the factory configuration on the Honeywell UDC2500 is on page 180 in the PDF manual from Honeywells website.
Steps:
1. Turn off power to the instrument for at least 5 seconds.
2. Turn power back on and simultaneously press the "FUNCTION" and the UP keys. This must be done while "TEST DONE" is being displayed.
3. If step was performed correctly, the instrument will now display "UDC" [Upper line] "UPDATE" [Lower line]
4. Press the "FUNCTION" key. The instrument will now display "DIS" [Upper] "RESTORE" [Lower]
5. Press the up arrow key. The instrument will display "CFG" "RESTORE".
6. Press the "FUNCTION" key. The instrument will display "DOIN" "RESTORE"
After that the instrument will go through a restart.
Hopefully this helps.
Mar 04, 2013 | Honeywell Udc2500 2 Output Relay Tc Input
Honeywell dolphin 6000 cold boot (hard reset)
Factory reset for Honeywell Dolphin 6000
With the pocket off press this combination of keys.
Up volume button, up cursor button, down cursor button and power button.
Then in a green window it will ask for reset all the dispositive by pressing the down cursor button or cancel the action by pressing any other key.
And thats the way of how to reset the Honeywell Dolphin 6000
Mar 15, 2012 | Computers & Internet
Please tell me how to reset my honeywell hz322 hvac zone panel.
There is a way to restore the Factory Defaults via the Advanced Configuration Mode. Be careful, this will require thorough knowledge of you system to reconfigure based on your particular system. Here is a link to the manual to assist you with the Advanced Configuration Mode.
Specifically, pages 6 & 7. Visit this link:
http://www.forwardthinking.honeywell.com/related_links/zoning/truezone/install/69_2071efs.pdf
Feb 14, 2010 | Honeywell Heating & Cooling
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
May 16, 2009 | Honeywell Programmable Thermostat Heater
Home Security Logo
956 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
