Question about Microwave Ovens
What is a parallelogram could you give me a shape please or a example or maybe directions or what a shape it is...
Can someone give me a answer about a parallelogram or directions or a example maybe a tip please because I need a shape or a number
  • 2,203 Answers
Take a square or a rectangle and push the top to one side . That is a parallelogram. But so are the square and the rectangle.
Posted on Mar 27, 2015
I have a GE Profile JVM192K convection microwave. I need a new 130v40w bulb for it.
The procedure and part number (WB02X4253) are on page 43 of your owner's manual.
If for some reason you don't have yours, you can download it here:
http://www.geappliances.com/search/older-pdfs/49-8524.PDF
You can find helpful exploded views and order GE parts from the Pros here.
Apr 22, 2013 | Microwave Ovens
Started with lights on ceiling left side three tube replaced tubes replaced board now getting f3h code
You may not get an answer because your question is very confusing. You are asking about a Microwave and talking about lights on the ceiling which appears to be a florescent which you replaced 3 tubes on, but then you mention a board and a f3h? None of this really makes any sense to me. Maybe someone else may be able to understand but I cannot. Please elaborate in detail.
Feb 03, 2010 | Microwave Ovens
Do commercial microwaves have some sort of feedback loop designed to reduce power when they are insufficiently loaded? In particular, I'm using a GE Spacesaver for a little science experiment where we...
HI,,
ITS A PROBLEM WITH DISCONTINUE VOLTAGE..
USUELLY COMMERCIAL MICR WV COME WITH IMPROPER HEAT OUT,,
FOR EXAMPLE IF U PUT TEMP ON 100 FHT IT WILL GIVE OUT 80 FHT..
SO I PREFER A BRAND MICRO WV..
TNKS
RABBANEES
Nov 11, 2009 | Microwave Ovens
How to set the clock on my sharp carousel microwave
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Sep 25, 2009 | Sharp Microwave Ovens
Microwave turns on by itself
You have a shorting keypad. This can be very dangerous and result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it;s not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find Magic Chef parts here.
If not, please reply back with your model number so we can help you.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
Nov 08, 2008 | Magic Chef CMV1000B Microwave Oven
Panasonic microwave touchpad not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may instead have a failed keypad.
If you would like to have us do this for you, we do that for $39.95 plus part costs, which depends on the exact model, one of these:
NNS688BA NNS688BAS NNS688LA NNS688LAS NNS688WA NNS688WAS
Please feel free to contact me directly if you need more help.
Oct 08, 2008 | Panasonic Microwave Ovens
Keypad is shorted out
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 22, 2008 | Microwave Ovens
Buzzing when surface lights turned on
Right. It sounds like either a bad connection on the control panel, or maybe a low or intermittent supply at the outlet.
I would try plugging a lamp into the outlet and see if it works well. That gives you a good low-current test. For a good high-current test, try a toaster or hair dryer.
You might also check the fuse and holder. It's pretty common for these fuses to get loose on the end caps and sometimes the holders may be loose.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
It is turns out to be the controller, we repair these for customers nationwide with our guaranteed $39.95 service.
prototech@usa.net
Jul 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Touch Panel Repair
I answered you about this directly via e-mail. Thank you!
We're happy to help and we appreciate your thoughtful rating of our answer.
For others with touch screen issues, please see the info at http://www.microwavedisplay.com
prototech@usa.net
Jul 02, 2008 | Sharp R-340 Microwave Oven
I need to talk to someone on the phone please my number is 1-360-495-3203 ask for JIM ty.
I'll be happy to follow up with a phone call, or feel free to contact me directly if you need more help.
prototech@usa.net
May 22, 2008 | GE Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
