Question about HP LaserJet 4000 Printer
Repiar instructions for HP 4000 printer
There is a repair kit with instructions to replace worn rollers in the printer. i'm looking for the instructions
    Top Expert:
  • HP Master
  • 1,144 Answers
HP 5100 paper feeding problem
Hello Paper feed problem are usually caused by worn feed rollers and separation pads. If you printer can not pickup the paper or pulls more than one sheet into the printer at a time then the rollers and pads need to be replaced. This is a user replaceable kit. You can get the kit here:
http://www.ccl-la.com/catalog/product_info.php?products_id=325
Apr 19, 2013 | HP LaserJet 5100 Printer
Hp laserjet 4250 feeds multiple pages through the manual feed tray
It sounds like the paper pickup roller and separation pad for tray 1 is worn and will need to be replaced. These two parts pickup the paper and weed the pages into the printer. When they get worn down they can grab more than one page at a time. The parts are user replaceable, no need to pay a big repair bill for something like this. The parts come in a kit with rollers and pads for tray 1 and tray 2 along with the instructions and it is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=302
Here is a picture of the roller and separation pad from the service manual.
I hope this helps you out.
Apr 11, 2013 | HP LaserJet 4250dtn Printer
Adf roller
try precisionroller .com
Jan 30, 2013 | HP LaserJet 3015 All-In-One Printer
HP Laserjet M2727 Printer picks up too many pages at once
You have worn pick rollers. This is an easy fix and you can install the new rollers yourself. You need a preventative maintenance roller kit part number RK-P2015. You can get them here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_70&products_id=128
The kit has all of the rollers and separation pads to replace the worn ones in the printer to restore proper operation.
I hope this helps,
BuddyMc
Jul 20, 2012 | HP Laserjet M2727nf Multifunction Printer
The sprinter gives a message cleaning the paper path
Check* was paper physical length is matching to selected length? *check Maintenance kit interval. * check which tray you are getting this message? tray/tray 2 check pick up rollers are warn out? * clean paper path sensors.
Sep 30, 2011 | HP LaserJet 4250n Printer
Paper jam light is blinking, cannot find any jam
You may be having a problem with your paper sensors. You may need to have the printer serviced by a technician to verify. This problem seems to be a regular event with this model.
Jun 08, 2010 | HP LaserJet P2015dn Printer
Paper feeder does not appeat to be able to 'grab' paper ?? what can i do
Please refer to the manual and then open the ADF clean the rollers and then try again some times due to dust in the rollers then paper is not feeded.
Apr 11, 2010 | HP LaserJet 2420 Printer
Repair Kit for HP 4MV Printer - Pick Up Rollers
The ruber tyres on the pick rollers can harden with age, even if you are not using it. Try applying gum turpentine to rubber tyre with Q tip. This is used to keep a printer picking up untill replacemant rollers can be fitted.
Dec 15, 2008 | HP LaserJet 1020 Printer
I have a HP Laser Jet 4000N sitting here in my office that makes a noise like the gears need oiled or some ****. Happen to know what I could use to help get them doing? When pulling a page from Tray 2; the...
This happens when the rubber on the roller is worn or has accumulated paper dust on it. The rubber is of a blue or grey color. Usually you can clean the gear with cotton swab and alcohol.
Also, there is a roller in the paper tray and a rubber pad that can be cleaned with alcohol.
If it is badly worn, you can order a replacement. There is a maintenance kit available which contains a fuser,transfer gear and up to six rollers. I keep one kit handy to keep my HP in top form.
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Oct 08, 2008 | HP Office Equipment & Supplies
HP 2420 Tray 2 Open or Empty
Needs feed roller replaced, you can see it when you remove cassette and look up, they wear and tray one uses a diiferent feed roller hence it still works. Cleaning the roller (rag with a little metho) sometimes helps but it should be replaced otherwise it will return.
Nov 08, 2007 | HP LaserJet 2420 Printer
HP LaserJet 4000 Printer Logo
57 people viewed this question
Ben Johnson
