Question about John Deere Garden
John Deere 4230 new starter replace battery also and still will not start
  • Dennis Key
    Dennis Key Mar 27, 2015
    Hi Ben Valenzuela, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • John Deere Master
  • 2,963 Answers
Ignition switch, connections at switch, or small post on the starter solenoid, or wire broken between the two. Or possible bad "new starter solenoid". It's been a problem for other starters. May be a bad batch of solenoids. You may be alble to veryify the solinoid by a jumper from the positive battery terminal or cable to the small post solinoid terminal. If it activeates the starter, you know the solinoid and starter are ok and the problem is the wire or connection to the starter switch. If you had problems before, It may be a bad ignition switch and the internal starter switch. Did you test the old starter? you may not have needed to replace.
Posted on Mar 27, 2015
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
SOURCE: John Deere 318 won't start. Replaced starter/alternator.
I don't think it's electrical. The starter gear gets jammed against the teeth on the flywheel. Try tapping the edge of the gear with a drift of some kind then try starting again. It won't solve the problem long term, but it will save you spending time troubleshooting an electrical problme that doesn't exist.
Posted on May 04, 2010
John Deere Z225 starting problem. The solonoid only clicks when I turn the key.I replaced the battery, the starter, the ignition switch and the starter solonoid!
With everything you have done only 2 things come to mind.
1) Safety switch open or not functioning.
2) Engine seized.
May 03, 2017 | John Deere Garden
Year model of john Deere 4230 serial number 4230h031250r
John Deere 4230
From the data on this web page, it was built late 1976.
Best of luck.
Jan 02, 2016 | John Deere Garden
John deere wiring diagrams
coud be but i think bad starter rebuild it thats cheap to do and easy to do
Aug 27, 2014 | John Deere Garden
John deere 110 on power to starter when key is turned
Did you replace the celanoid it is between the battery and stater and if it goes bad it won't start. And I don't think that is how you spell it just follow the red wire off the starter back and you will find where it hooks to it then goes to the battery
Nov 03, 2013 | John Deere Garden
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
163 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
