Question about John Deere Garden
My John Deere mower won't start when its cold. It starts right up if I prime it by shooting it with starting fluid or dumping gas down the carb.
It will start after it has been started the first time for the day. It only has problems on the initial start.
  • John Deere Master
  • 2,478 Answers
Take the fuel line off carb, and see if fuel runs out. Your fuel cap vent may be plugged.
Posted on Mar 27, 2015
I replaced fuel filter and pump but no gas flows to the fuel filter
Hi Bethant:
I've had a similar problem with my Craftsman since I bought it.
At every cold start I have to remove the air filter and toss a thimble volume of gas into the carb to prime it. It then starts instantly and runs fine. Will restart while hot but not after a few hours.
I realize that priming it does not solve the problem, but unless I install a manual primer in the fuel line I'll just accept it.
Hope this helps,
Cheers
Jan 29, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Has spark fuel and 125 compression will not start?
Use a small amount of starter fluid in the intake past the filter. If the engine fires than you can be confident it is a carburetor problem.
Check for water in the gas
The carb cleaner may not be volatile enough to support ignition. The over the counter starter fluid is easily ignited even in cold weather.
If the engine has been in storage with old gas it is likely that residue has formed in the carburetor. If it does fire up with stater fluid but will not run with full choke it will most likely require a carburetor cleaning.
Jan 08, 2016 | John Deere Garden
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
Gardenline petrol mower model 8846 wont start
I have a John deere L118 with a 42" and snowblower that wont start without a direct prime in the carb then runs fine. I adjusted the valves from another post (that did work for a small engine i had) but no change this time. I pulled the carb and found it clean except the o ring above the solinoid at the botton of the bowl had expanded and was not sealing the gas the way it should. Put a new one on and cleaned and air blasted just in case. Re assembled and it would not start. I turned it over and found the gas flow was as weak as a old old guy with a prostate problem. I decided to install a primer bulb just after the gas filter and it starts up every time. if it uses a gas pump to hold the prime and it does not have the engine crankcase pressure on start up to squirt extra pressure thus gas into the carb when cold, this will tax your battery and starter before it starts. I installed a Honda car battery by cutting the housing slightly. because when it snows in ontario Canada, and its cold, You want that puppy to bark!
Jan 08, 2014 | Garden
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Sep 01, 2012 | John Deere Garden
Won't stay running after prime runs out
starving for fuel. first check for bad/old gas, then restrictions in the fuel delivery including fuel line, filter, or buildup of debris in tank or any sharp bends or 90deg. fittings. then pull the float bowl and make sure the float is regulating fuel fuel into the bowl, but most likely your main jet is plugged. use a fine piece of wire like guitar string to runthru the jet located at the lowest part of the carb that hangs down into the float bowl. the jet will be on the side or bottom of this lower piece. put bowl back on, get gas to the carb and recheck starting problem. good luck. R
Aug 27, 2012 | John Deere Garden
Lawn mower will not start
If on John Deere D130 riding mower charge the battery, put 4- 6 ounces of carb cleaner in gas tank with the gas in tank, let sit
for 3-4 hours. Should start when fuel primed up. this has helped
me from service calls 3 times now
Jul 07, 2012 | Garden
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
Garden Logo
124 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
