Question about Giant Bicycle Inc. Cypress SX
How to adjust handle bar slope giant cypress - Giant Bicycle Inc. Cypress SX
What year was a giant cypress bike serial number 6s762902 made
Google "Giant serial number" to see if a database is available. If not see my tip for other options. BUT generally year, model is not that important. How to determine the year value etc of your bicycle
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Aug 11, 2017 | Giant Cycling
Giant Cypress DX. How do i remove the front tire?
unthread the axle bolt on both sides and lift it off the frame .
Apr 17, 2016 | Cycling
How can I tell what year my Giant Cypress DX bike is?
Made from 2009 to 2014. Have to ID by paint scheme, equipment, decals. Search model at BikePedia
Mar 19, 2016 | Giant Cycling
How do I raise handlebar on giant mtx150
Likely uses an ahead set type handlebar setup. There might be spacers that you can move from over the bar to under, but if you are looking for a lot of adjustment, puchase a new stem that is adjustable.
Jan 10, 2015 | Giant Cycling
Creaking noise from handlebar stem on giant cypress bike
Hi Martin, I would suggest you ask them to check your headset as well, that could also cause the noise.
But if it is the stem, get some carbon paste from a shop and loosen your stem yourself, apply the paste thinly to all surfaces that makes contact and tighten it again.
That should keep it quiet, but something else to keep in mind, don't ever use high pressure cleaning equipment on your bike!
Dec 20, 2011 | Giant Cycling
How do i lock front wheel axil
Web search "operate qucik release skewer"
Aug 07, 2011 | Giant Bicycle Inc. Cypress
How do you adjust the saddle down?
Loosen the bolt on the tube that holds the stem of the seat. The seat will adjust all the way down to the top of that tube. Bolt should be 1/2 or 9/16 or 12 mm
Apr 26, 2011 | Giant Bicycle Inc. Cypress LX
How do I raise the handle bar height on my Giant Trance
Flipping it over might work, or get one with a higher rise, different reach. Get a bike shop to assist as there are 4 parameters to match up: steerer diameter, handlebar diameter, reach and rise.
Mar 06, 2011 | Giant Trance X4
How do you hire the handle bars on a giant mountain bike
Hello. You will need an adjustable wrench. Then look at the center of the handlebars and you will see a bolt and a nut. Usually the nut is on the underside. Loosen the nut, raise the handle bars and retighten the nut. J.
Jun 01, 2010 | Giant Boulder Se Mountain Bike 19"...
Giant Bicycle Inc. Cypress SX Logo
188 people viewed this question
Top Giant Bicycle Inc. Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Giant Bicycle Inc. Cycling Expert? Answer questions, earn points and help others
