Question about Caliber Optics
Serial # 383173. Can you give me approximate date and what caliber it is? Thanks
  • Caliber Master
  • 2,170 Answers
Nope as with out a manufacturer and model that number is on dozens of weapons
Posted on Apr 28, 2015
  • Anonymous Apr 28, 2015
    Duh, it's a Marlin '92, rim fire, 32/40, octagonal barrel. Hope that helps.
  • james laughton
    james laughton Apr 29, 2015
    Due to missing records post 1906 the best I can do is 1906-1915 probably closer to the earlier date calibre wise .32rf or .32 short centerfire as they came with two firing pins finding rf next to impossible hand load .32 short from .32 long cases if you can find enough of them to cut down
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 | Firearms
Age and caliber model99 serial number439592
Your Savage Model 1899/99 was manufactured in 1947 according to this website: Savage 1895 1899 99 Dates of Manufacture
Nov 16, 2016 | Caliber Optics
What year was model CTX14CYZBRWH serial number RS730854 manufactured?
Katina,
GE is one of several manufacturers that recycle their model and serial numbers every few years. I have included a link to a website that gives the approximate date of your refrigerator.
Appliance411 Service How old is my appliance Age finder date of...
Jun 02, 2015 | Refrigerators
Hi there, i want to find out what year my Transonic 14" Colour Television was manufactured. Its model: CE 1497
most TVs have the manufacture date on the label with the model/serial number. You might also check inside the unit, some parts may have a date stamp to give you an approximation.
Mar 03, 2015 | Televison & Video
In what year was serial # VF34911797 manufactured?
william, i am attaching a link to a website that i use for dating appliances that i work on. it gives the approximate date your stove might have been made and also shows a picture of a label that shows were they put a date code. appliance411 service how old is my appliance age finder date of...
Jan 16, 2015 | Kitchen Ranges
Lookup serial numbers
The Singer web site dates the serial number to approximately 1956. That is all the information there. You can try to use google images of Singer machines to find the model number than try the Singerco.com web site for additional information regarding features.
Aug 26, 2014 | Singer Sewing Machines
Just bought a vintage Citizen Super Crystal Date stainless steel watch. Serial No. on back is 00625090. Can you provide the approximate or exact date of production? Thank you.
We cannot tell you from the serial number what the model watch you bought is . But you can call Citizen watch 800 321 1023 extension 4234 and give them the serial and they will be able to tell you the model and year the watch was produced.
Oct 14, 2010 | Watches
Where is the serial number located on a remington model 37 rangemaster, cal,22 rifle?
693f0fe.jpg Introduction Year: 1936 Year Discontinued: 1955 Total Production: Approximately: 12,200 Designer/Inventor: C.C. Loomis, A.L. Lowe, K.J. Lowe Action Type: Bolt Action – Clip Magazine Caliber/Gauge: .22 Long Rifle Serial Number Blocks: Starting: 00001
Ending: 12300 Grades Offered: Model 37 Rangemaster
37 Target
37AR
37AF
37AX
37AM
37AV
37AS Variations: None
Dec 11, 2009 | Remington Sport & Outdoor - Others
Optics Logo
85 people viewed this question
Top Caliber Optics Experts
Mark Campeau
Level 1 Expert
ray gallant
deton8 von Splosion
Are you a Caliber Optic Expert? Answer questions, earn points and help others
