Question about RTO Ho Herpa Freightliner Truck Tractor
My power steering fluid was leaking I use power steering stop leak my steering got hard.
    Top Expert:
  • 2,899 Answers
I've been told to never put stop-leak in anything.
Best bet is to have a mechanic find the leak and repair it.
Could be only a loose fill or drain plug.
Hope this helps.
Posted on Mar 27, 2015
Why does my van's power steering fluid leak out as quickly as added if the van is running?
Burst power steering hose.
Cracked power steering hard line.
Bad seal in power steering pump.
Lose fittings on power steering lines.
Check power steering components for signs of leaking fluid.
Apr 11, 2015 | Cars & Trucks
Power steering not working, and put power steering fluid in car
Lets use common sense here
It leaks,you stop using the car & repair the leak
Most likely the steering rack is worn & needs to be replaced
That's what happens when you don't flush the fluid every
3 years or it leaks & runs low
Oct 10, 2012 | Ford Taurus Cars & Trucks
Bleed power steering on 2008 dodge avenger
to bleed power steering, with front wheels off ground slightly with front wheels pointing straight ahead.engine off. remove power steering filler cap.add power steering until fluid level stop dropping,wait couple minutes and wait, add fluid until level stay at full cold mark on power steering cap dip stick. dont over fill.when fluid level stop dropping, start vechicle,let it idle few minutes. see if fluid level drop if so add more fluid full cold mark.then turn steering all the way to left and right with out hitting a stop.turn steering wheel several times, then turn front wheels pointing forward check power steering fluid level.if power steering fluid level stop dropping air should be out of system, if steering turning wheel dont turn smoothly and power steering fluid look light tan color air getting in the system.check all power steering lines to rack and power steering pump for leaks.be sure you replaced all the power steering lines with new o rings if not you will get a leak.if you find a leak, you need to fix the leak and bleed system again.dont drive vechicle if your steering dont feel right,have vechicle towed to a garage.
Aug 25, 2012 | 2008 Dodge Avenger
The power steering isn't working. The reservoir was empty and I added power steering fluid and it still very hard to steer
YOU HAVE A RUPTURE PRESSURE LINE IF YOU HAVE NO POWER STEERING FLUID IN THE POWER STEERING RESERVOIR.LOCATE LEAK THEN BLEED POWER STEERING SYSTEM BY ADDING POWER STEERING TO RESERVOIR.DONT OVER FILL BY FULL COLD MARK ON POWER STEERING DIP STICK.ADD FLUID TO RESERVOIR WAIT A 2 MINUTES.CHECK FLUID LEVEL AGAIN.WHEN POWER STEERING FLUID LEVEL STOP DROPPING.START ENGINE LET IT RUN FOR 10 SECONDS.THEN TURN OFF ENGINE CHECK POWER STEERING FLUID ADD FLUID IF FLUID LEVEL DROPS. WHEN FLUID LEVEL STOP DROPPING.SAFELY RAISE SUPPORT VECHICLE FRONT WHEELS.START ENGINE.NOW TURN STEERING WHEEL GENTLY FROM STOP TO STOP MEANING LEFT TO RIGHT DONT HOLD IN POSITION.LET THE STOP TO STOP BE QUICK.CHECK POWER STEERING FLUID AFTER YOU HAVE TURN STEERING WHEEL ABOUT 7 STOP TO STOP.WHEN FLUID LEVEL STOP DROPPING YOU AT HOT MARK ON DIP STICK BLEEDING PROCESS COMPLETE.TURN OFF ENGINE LOWER VECHICLE BACK TO GROUND WAIT ABOUT 5 MINUTES CHECK YOUR FLUID LEVEL.IF FLUID LOOKS LIKE A TAN COLOR.YOUR POWER STEERING SYSTEM FULL OF AIR.TURN OFF VECHICLE LET VECHICLE SET A LONG WHILE TO AIR BUBBLES SETTLE DOWN LOOK FOR LEAKS AROUND POWER STEERING PUMP FRONT SEAL AND CHECK FOR LEAKS AROUND POWER STEERING LINES.
Dec 01, 2010 | 1999 Oldsmobile Alero
Brown fluid leaked and steering wheel locked up on 99 jeep grand cherokee
Check the power steering fluid. The resoviour could have a leak in it. This is located under the hood normally it has a cap about the size of a half dollar
Nov 28, 2010 | Jeep Grand Cherokee Cars & Trucks
My Nissan Maxima '92 leaks power steering fluid. I had someone look at it but they couldn't find the leak. I just put in new fluid every few weeks and it works fine but if there is an easy fix I would like...
if there is a leaking seal in the power steering rack and pinion or in the hydraulic pump, a power steering stop leak may swell the seal enough to stop the leak. if there is still a leak, it is likely a damaged / corroded line or fluid cooler. next time you need to top up your fluid, i recommend Lucas brand power steering stop leak / treatment. after a couple top ups it will stop the leak it if is a rubber seal problem. good luck!
Jun 21, 2010 | Nissan Maxima Cars & Trucks
Ford mondeo 1.8 td diesel, the problem is the power steering fluid is leaking, when i check it look like it was coming from the middle part of the radiator.how can i fix it and what parts do i need to get...
Have a look at the power steering fluid cooler it is just in front of the radiator behind the front bumper. The coolers corrode and leak. Also the seals can go, check for fluid leaking out of the boots at the track rods. Try this procedure :--- 1)Trace the source of the leak. Use a mirror on an extended handle to follow the puddle of fluid on your garage floor to the power steering system. Look on the hoses and gaskets to find from where the fluid could be leaking. 2) Add power steering stop leak additive to your power steering fluid. Lucas Power Steering Stop Additive is 100 percent guaranteed to stop seal leaks. In older cars, the seals shrink, causing leaks. The stop leak makes the seals swell to their original size. 3) Use gasket sealant if the gaskets are old and leaking. Sealant, such as Permatex, is resistant to engine fluids, and will help repair a leaky gasket. 4) Replace the gasket, if the gasket sealant does not work. Thanks. you can rate this solution and show your appreciation.
May 19, 2010 | Ford LTD Cars & Trucks
Plz help 1996 Volkswagen Jetta
stp makes a p/w steering fluid with stop leak but this usually only works if leak is minor.you can try this for a few bucks and if leak doesnt stop then repairs are most likely needed. chris
May 09, 2009 | 1996 Volkswagen Jetta
Power Steering Fluid
sometimes adding brake fluid to the power steering pump will stop the leak if its not to bad.you may have to keep adding as it leaks down untill you use about a bottle ,before it stops the leak.
Feb 22, 2009 | 1995 Nissan Maxima
Power steering rack 1998 toyota camry
I have a power steering leak on my 1998 Toyota Camry.  I have been using over the counter stop leaking fluids, but it has not helped.  It leaks more during the cold weather as oppose to hot weather. Deme
Jan 24, 2009 | 1998 Toyota Camry
RTO Ho Herpa Freightliner Truck Tractor Logo
102 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
