Question about Wolf Range Convection Oven Electric Double Deck 70inx40inx43in
Hi there, Could you please help. Yesterday I ran the self clean program on both ovens. Since then I have been unable to get the ovens to heat up. The fan is coming on as if to heat - but no heat. The control panel is reading 'lo preheat'. When I enter a hotter temperature setting they just revert back to Lo Preheat...they are both doing exactly the same thing. Any ideas please? Many thanks Wendy
  • 2,223 Answers
Check ur circuit breakers, there are two in tandem. One may have tripped.
Posted on Mar 27, 2015
Testimonial: "sorry, where is the circuit breaker??"
  • 5 more comments
  • wendy
    wendy Mar 27, 2015
    where do i find the circuit breaker?? :-)
  • rdjagger Mar 27, 2015
    You know: fuses, circuit breakers. In a fuse/circuit breaker box on a wall some where. Side of house, garage, closet, basement. Controls all of the electricity that comes into ur house. Ask some old retired guy (like me) in the neighborhood to help you
  • wendy
    wendy Mar 27, 2015
    lol oh, yes I tried that, but the oven still says Low preheat. I thought you meant on the actual oven. All the other electrical appliances work apart from the message on the oven which now doesnt heat??
    Did the self clean cycle run properly and completely?
  • wendy
    wendy Mar 27, 2015
    no, the "circuit breaker" tripped
    well then a couple more things: the circuit breakers may not have fully reset. try tripping the back and forth a couple of times. they are mechanical and made of a bimetal in a spring and might get hung up. do it fast but pause a bit between flips. if that does not work, then it could be that you had a loose connection in your plug, plug in or wire harness connected to the oven. ithe loose connection might have arced and burned out during the self clean. the circuit breakers may be bad and just need to be replaced. hope the flipping works if you have not already tried that. if not, you need that retired guy or an electrician to help you out it believe. most ovens do not have an internal fuse or circuit breaker, but yours might i suppose. check you owners manual or find one online for your make/model. best of luck.
    any luck?
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kenmore Ovens
Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
heatman101
Aug 24, 2010 | Thermador SC302T Electric Double Oven
My built-in electric oven will not heat now, following the self-cleaning cycle I ran yesterday.
Frustrating no doubt. There are several things that can cause this and they vary by manufacturer and model. Sometimes the high heat causes a fault in the temperature sensor or its wiring. Other times it causes the control board to fail. We repair a lot of control boards that fail after a self-clean cycle. If you post more details: make, model, any other observations I may be able to shed more light. Or you can email me details at bruce@fixyourboard.com.
Best Regards,
Bruce
www.fixyourboard.com
Oct 14, 2009 | Ovens
I have an older GE self-cleaning oven. It has an
Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Sep 23, 2008 | Thermador Professional Series PO301...
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Wolf Range Convection Oven Electric Double Deck 70inx40inx43in Logo
975 people viewed this question
Top Wolf Range Cooking Experts
Tom Chichester
ray gallant
Are you a Wolf Range Cooking Expert? Answer questions, earn points and help others
