Question about Intex Pool & Spa
What is psi for Intex model 637r - Intex Pool & Spa
  • Intex Master
  • 1,631 Answers
Will it pump with no filter?
Did you replace with new filter?
do you have valves? Are they open?
Pump could be bad, broken impeller!
Posted on Apr 19, 2015
2 Suggested Answers
  • 16 Answers
SOURCE: I have a intex 637R pump and the problem is it doe...
I have the same problem. I've replaced the filter and made sure nothing was blocking the inlet or outlet but it barely pumps. I also bled the air out.
Posted on Jun 27, 2010
My pump doesn't come on at all after checking breakers model 637R
is there power to the switch and after the switch if so bad pump motor
Sep 04, 2014 | Pool & Spa
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
Intex pump has code 01
What model of Intex pump do you have? Have you been back flushing and rinsing regularly?
Jun 14, 2014 | INTEX Sand Filter Pump
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
I have a fairly new (1st season) Krystal Clear Model 637R. It ran fine for a few months but now I can only keep it running for about 5 minutes before it shuts down. I then have to take the top off and...
I would check the hose connections again. Plus on the filter pump housing where the hoses hook up there should be orings. Check those to insure they are not dry rotted or if they slipped out of their groove.
Jul 22, 2011 | Intex Pool & Spa
Where i search intex webcam drivers
as soon as possible to solve the problem of drive
Aug 07, 2008 | LG LPC-UC35 Webcam
Pool & Spa Logo
155 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
