Question about Samsung UN46EH5300FXZA
Has sound. Why no picture, no backlight? - Samsung UN46EH5300FXZA
Need a backlight for vizio model E550i-B2
Fixya does not sell replacement backlights.
Oct 08, 2016 | Vizio Televison & Video
How do you fix a Samsung 55" Television with no picture but good sound?
The symptoms you described would indicate the backlights are not working.
The 2 main reasons are the backlight inverter board has gone or the backlights have blown!
Since you have replaced the inverter board with a new working one then this would point towards the LED backlights.
Apr 02, 2016 | Samsung Televison & Video
I have sound but no picture. The picture can be seen by shining a torch(Flashlight) on it. What needs replacing please?
The backlight has failed. If it is an LCD television, likely the fluorescent backlight or the ballast has failed. If it is an LED television, the backlight driver has failed.
May 16, 2015 | Televison & Video
When the tv set is put on, no picture shows but the sound is ok
Check If there is a backlight?
With Backlight, With sound....Main Board
No Backlight, With Sound.....Power supply (24V) or Inverter Board (Capacitor)....
Oct 27, 2013 | Toshiba Televison & Video
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.It a long board in shape.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 17, 2010 | Sansui HDLCD3210 32 in. LCD TV
Picture come on for about 2-3 minute, then goes out has sound no picture, red light come on near power button
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board to get the picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 03, 2010 | Philips 60PL9200D Projection Televisions
No picture
If we first establish if the tv has actually come on and out of standby. If this is the case, gently press on the lcd with your finger..Is there any backlight showing ? Is there any sound on the TV? If there is sound and no picture and no backlight your problem will be the invertor. If there is no sound, no backlight, the fault most probably is the power supply board, and could be a fuse or capacitors going 'dry' with bulging tops. If there is backlight and sound, the problem will most likely be main pcb or the Tcon pcb (mounted on the LCD rear top middle).
Feb 13, 2010 | Samsung LE22A457 22 in. LCD TV
I have sound but no picture??
vague discription , but can help here, is the backlight lit?
if not
shine flashlight on screen and see if any picture is actually there,m if there is a picture there with no backlight, could be a power issue or bad panel (screen).
if no picture but has backlight, may be Tcon board or signal board
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 27, 2009 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Samsung UN46EH5300FXZA Logo
357 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
