Question about Vtech IS7101 Extra Handset / Charger
Hand set stop working - Vtech IS7101 Extra Handset / Charger
Regular hisense TV 42 inch remote stopped working need to change input buttons on bottom help
Hi
Anonymous, It is the remote hand set which goes bad. Please have the hand set checked for defective crystal oscillator, old batteries, and failed IR LED. There may be some internal damage due to falling also.
Jun 13, 2015 | Hisense Televison & Video
Trying to replace the stop light switch on a 1986 toyota 4runner
Move into a position where you can easily see underneath the driver's side of the Ford pickup's dashboard. How you do this depends on your physical size and dexterity.
Shine the flashlight on the brake pedal arm to illuminate the stop light switch and the stop light switch mounting bracket. Unplug the Ford pickup's brake light wiring harness from the switch by hand.
Read more: How do I Replace the Stop Light Switch in a 1986 Ford Pickup? ' eHow.com http://www.ehow.com/how_7655525_do-switch-1986-ford-pickup.html#ixzz21tSRtoDU
Unbolt the stop light switch from the stop light switch mounting bracket using the box wrench set. Take the old switch down by hand and place the new switch on the bracket.
Bolt the new stop light switch to the bracket with the socket set. Plug the brake light wiring harness into the Ford pickup's new stop light switch by hand.
Jul 28, 2012 | 1986 Toyota 4Runner
Fuel gauge has just stopped working on my peugot
if you hit the dash with the palm of your hand, does the hand rise at all? if so, then your car needs a set of dash clocks.
Mar 18, 2010 | 1991 Peugeot 405
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
I am trying to adjust it to the proper time and when I pull out the 'crown' the time does not stop and so I cannot adjust it. Should I wait for it to stop and then try to reset the time?
frasermundia,It sounds like you want to "hack" the setting...ie, stop the second hand when setting the time...however, this specific automatic movement isn't designed to do it. You might be able to get the second hand to stop...after unscrewing the crown and pulling it out to its 2nd position...by slightly turning the crown back and forth very small amounts; it's a bit flukey and doesn't always work. Your other option is to let it run out of reserve power and stop, as you said...and then set it and wind it.
Nov 18, 2009 | Invicta Automatic Pro Diver 8926 Watch
HI, i have a gucci watch YA077310 and i dont know how to set it. also the second hand does not work.
To set the time, you normally pull out the crown and rotate it. The main (large) second hand is associated with the chronograph function so is stopped at 12 when no using chronograph. There should be a little second hand in a little round area on dial that is moving.
Jan 26, 2009 | Gucci 7705 Chronograph YA077310 (17736)
Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Dec 22, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Vtech IS7101 Extra Handset / Charger Logo
186 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
