Question about Mitsubishi Televison & Video
I have wd-73738 and replaced the lamp and color wheel after 5min it colors flickers.
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Posted on Jun 10, 2009
SOURCE: 62HM95 lamp will not work after color wheel motor replacement
I have the same tv 62HM95 can u tell me what is the color wheel
Posted on Aug 06, 2009
chesterpendi
  • 195 Answers
SOURCE: My 73'' mitsubishi model #wd-73738. Is flickering.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Or try replace light engine..if the above solution won't work..
Posted on Feb 23, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a Mitsubishi WD-65731 65" HDTV. color issue, when it comes on it has great color for about 10 minutes, then the color goes to purple, greens, and light flickers. Have replace lamp, did not help
what error code is found if do self check?
Posted on Apr 19, 2012
My Mitsubishi model WD 65735 constantly flickers. We've gone inside and cleaned it besides the color wheel. Any reasons why?
If you have changed the lamp or due to age, the lamp socket can crack and lose connection. Check to see if it is intact.
Feb 10, 2017 | Mitsubishi Televison & Video
What is wrong with Mitsubishi tv Model WD:82738? I just replaced the lamp and it is making a sound like a bearing rubbing and the picture is flickering.
It sounds like your color wheel is going out. Here is the part#. If you do not feel cofortable with this type of repair, please have a servicer do it for you. Good luck to you.
May 23, 2016 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Mitsubishi wd-65738 flickering
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 25, 2017 | Mitsubishi WD-57833 57" HDTV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Jun 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
