Question about Hotpoint Refrigerators
Compressor not running, water light flashes about two flashes per second.
    Master:
  • 416 Answers
It doesn't run
  1. Check outlet
Make sure the refrigerator is actually plugged in and that the outlet is functioning properly. If the outlet is working correctly, take it one step further and check the circuit breaker in your home.
  1. Check connections/wiring
Check your connections to make sure there is no corrosion.
  1. Compressor
If your compressor fails to operate this may be an indication that it is time to replace the defrost timer.
  1. Overload relay
If your overload relay continues to shut off in spurts then the part is weak and requires replacement.
  1. Thermostat
It is likely that you have a bad thermostat. Try resetting by turning it off, then on to reboot. If this fails replace the part.
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective.
Posted on Mar 29, 2015
Testimonial: "I unpluged the evaporator fan and every thing else started working so I replaced the evaporator fan working good now."
    Director Badge:
    Uploaded 100 video answers.
  • Hotpoint Master
  • 488 Answers
Broken or bad connection under freezer door hinge. Wiring going to dispenser board. Im pretty sure its might be wet as well. find that connector under freezer door hinge. Let me know.
Posted on Mar 28, 2015
The fridge make weird noises some days. Cooling is good, freezer also works well. My concern is if those noises are prelude to a major damage.
This really depends on the type of noise. If you hear a gurgle type noise while running this is usually normal from the refrigerant pumping through the tubing. Fan type noise blowing air in the freezer section is also normal but if it sounds link the fan is rubbing or grinding you need to look into that noise. Also a similar fan down near the compressor area in the lower back section. A low hum from the compressor while running is normal. If you have and icemaker--water running noise about once per hour for around 10 seconds is all normal while the icemaker is filling. Dropping noise from the cubes falling into the bucket is also normal about once per hour. Hope this helps.
Jun 10, 2015 | Refrigerators
Program light and time flash once per second
Here's the link to the user manual if you need it; http://www.cuisinart.com/share/man/34_man.pdf The water filter should be fine - if not it should be obvious to the eye that it is blocked/restricted - hold it up to the light. Try running through the descaling procedure in the manual if you havent recently - if it doesnt let you run a cycle, try it overnight without running it, and see if it will let you run a vinegar cycle in the morning. Try and pour vinegar into all the parts you can where it would go if a cycle was able to be run. If that doesn't get it running, check that none of the program/time setting features are still on - they should turn off after a few seconds, but maybe it is stuck in "time set" mode or similar. If none of the actions in the manual change the setting, try unplugging the unit and leaving it for at least half an hour unplugged, then hold down the power button when you plug it back in - this should reset the machine. If the reset doesn't work, it sounds like you have a control board fault - best solution is to contact cuisinart; http://www.cuisinart.com/contact/ Hope this helps :)
Aug 01, 2007 | Cuisinart DGB-600 Coffee Maker
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
How to disable seatbelt alarm on 2003 F-150?
There is a procedure in the owners manual on page 110.
BeltMinder activation and deactivation procedure
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE.)
2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes.)
• Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled
• After step 5 the safety belt warning light will be turned on for three seconds.
6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
• This will disable BeltMinder if it is currently enabled, or enable BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by the safety belt warning light flashing four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by:
• The safety belt warning light flashing four times per second for three seconds.
• Followed by three seconds with the safety belt warning light off.
• Once again, the safety belt warning light will flash four times per second for three seconds.
9. After receiving confirmation, the deactivation/activation procedure is complete.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Dec 20, 2009 | 2003 Ford F150 Regular Cab
Engin light is on how to check codes
To check for trouble codes turn the ignition switch to run for three seconds (one second pause after the fuel pump stops running) and then turn the switch back to off for three seconds. Repeat this process again. Now turn the switch to ignition and wait for about 8 seconds and the check engine lamp will start flashing the codes. If there are codes present the light will flash rapidly (about three per second) then there will be a 2 second pause with the lamp off. The lamp will then flash one or more times to indicate the first digit of the trouble code. It will be on and off for about 1 second. Count the number of times it flashes for the first digit of the trouble code. Then there will be about a 2 second delay then will flash again for the second digit. After flashing the second digit there will be a 2 second delay and additional trouble codes will be flashed. Write down the numbers and when they start repeating themselves the trouble code transmission is completed. All trouble codes consist of two digits.
If the lamp flashes only the 3 flashes per second there are no trouble codes present.
If there are codes present, let me know and I can advise you of their meaning.
Oct 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Error light flashing
Toner is empty for slow flash 1 per second
Toner is low for quick flash 2 per second
Aug 16, 2008 | Konica Minolta PagePro 1400W Laser Printer
No A/C
It seems that that the overload of compressor is tripping on and off, either your compressor overload is defective or the compressor itself
Sep 06, 2007 | Danby DPAC8399 Air Conditioner
Refrigerators Logo
60 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
