Question about TCL LE39FHDF3300 39 Inch LED LCD HDTV
How can i access the service menu on a TCL L42B2500 that's the model number I'm on the tv but i can't find it on line I'm having a problem with a flip screen an the pictures is solarized
Tcl TV has black lines and coloured broad line at bottom , can it be fixed DIY ,if so , how ?
Hi, it seems an issue with LCD panel or video processing board, if you have knowledge about Electronics you could fix it, but if not the best choice is to contact a TCL Service center or a qualified TV service technician.
Jan 05, 2018 | Televison & Video
How to unlock tcl tv. My tv turned to child lock. I dont have the remote help plss
Go to Google, and type in, 'how to disable child lock for TV model #' (type in the model of your TV); or you may be able to utilize the buttons directly on the TV that would allow you to access the menu that would display the option to disable the child lock function.
Nov 10, 2014 | Televison & Video
How do I record on a TCL Model L32E330, using a USB stick
Use the timer record function in the tv guide or timer reord in menu on unit
Jun 02, 2014 | LG Tcl L40fhdf11ta Tv Part Main Board...
8 solder ic number for tcl falt tv
Can you please check for any jammed buttons on the remote and/or control panel? Try switching on the TV manually, while removing the batteries from the remote. If you notice same problem, the area to be looked into is around the system control area: like dry solder, leaky/dry capacitors and this should be done only by a qualified service technician.
Aug 25, 2012 | Televison & Video
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
Tcl tv service menu code
i want to know TCL TV AT2965U service code.
Dec 21, 2010 | Televison & Video
My tv is a tcl brand model tcl-14175 i accidentally on the child locked.can I have the child lock code for my tv?please
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
Sep 24, 2009 | Tvone TV-207 Television
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Jun 15, 2008 | LG 30FS1D TV
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
TCL LE39FHDF3300 39 Inch LED LCD HDTV Logo
89 people viewed this question
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
robert
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
