Question about Hoover Dryers
VHC691B-80 rotates but doesn't heat up
All of the warning lights were flashing, changed the heater that comes with thermostats fitted, it worked for a week and then I got the same problem, I've tried another new heater but it didn't work this time - any ideas what the problem is likely to be now?
  • colin_rob310 Mar 31, 2015
    The vent and lint basket are clear, they were cleaned out when I fitted the first replacement heater. The heating element shows resistance and is therefore OK, voltage to the drier is OK. Where is the thermall cutoff installed? The thermostats show no resistance & are therefore OK. I can’t see the moisture sensor on the door is there anywhere else to look?
  • Jorge Rendon
    Jorge Rendon Apr 07, 2015
    as for the moister sensor for ur model Im not sure, do u have ur schematic? the thermal shut off is usually located on the blower next to the 4 pronged cycling thermostat. back to the moister sensor try looking along the back wall for silvery shiny metalic objects
  • Hoover Master
  • 5,323 Answers
Check venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Posted on Mar 30, 2015
  • 7 more comments
  • Jorge Rendon
    Jorge Rendon Mar 31, 2015
    are u saying the thermostats show infinity? and no ohms? or do u get a OHMS reading? in other words a closed circuit, when u say voltage to the dryer is ok , u mean a full 220 is shown? the thermal shut off is located on the blower nest to the cycling thermostat. But when it blows u get nothing. did u test ur moister sensor yet? or in some cases a thermistor?
  • colin_rob310 Apr 01, 2015
    The thermostats show continuity ie very low resistance reading (I only have a cheap multi meter, it shows about 0.7 on the lowest Ohms setting) so a closed circuit. Voltage at the dryer is the full 240 at the terminal points on the relay. On my heater assembly all I can see is the two thermostats they both show a similar closed circuit reading. I've now located what I believe must be the moisture sensor (looks a bit like a silver top hat shape, on my model it is in the recess for the lint filter -is this right?) looks like I have to take the door off and then the front panel of the drier to access so won't check this until tonight.
  • Jorge Rendon
    Jorge Rendon Apr 02, 2015
    yes the moister sensor is there. as for the thermostat readings the low resistance or ohms poses no problem long as they are closed circuits. u did check the cycling thermostat also on the blower it has 4 prongs? the cheap mete ru have is fine
  • colin_rob310 Apr 02, 2015
    Hi, thanks again for replying. I haven't checked the cycling thermostat, the heater only has two thermostats on it which each only have two connections, where else might this other thermostat be?
  • Jorge Rendon
    the other 2 thermostats are located on the blower unit. 1 is the thermal shut off and the other with 4 prongs is the cycling thermostat
  • Jorge Rendon
    on ur heater is there a place for another fuse thermostat like a tiny hole spot with 2 slots for screws
  • Jorge Rendon
    ther eis usually 2 at the top and 1 near the bottom heater connection
  • colin_rob310 Apr 07, 2015
    Hi, I thought I'd already posted a reply to this but I can't see it. I took the item out of the door/lint filter recess it shows a resistance of 21k ohms which I believe is correct, I'm still struggling with location of the other two thermostats that you refer to, they are definately not in the blower air channel and they are not on the heater. Any more help would be appreciated.
    Should have mentioned in the Hoover spare parts listing the item in the filter recess that I'm referring to is listed as the NTC probe.
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore 80 series electric dryer won't heat. I
The bottom limit is engineered to open at 250F and the small top one is supposed to open at 300F. The bottom did not have time to click in and so it is considered weak. the kit comes with both thermostats in it Part number 279769
Posted on Mar 07, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Dryer's drum won't rotate, but heat & timer works.
Hello there:
This is normally caused by a belt that has either broke or the motor for the belt has failed and locked up
S o what i would do is to first see if you can manually turn the drum by hand and if so than if you turn on the dryer and hear the motor that turns the drum running or humming you can assume that the motor is ok and that he belt has failed in this case get a new belt and the appliance parts store should be able to give you the proper diagram on how the belt needs to back on but if not let me know and i will be able to get it for you ok? now if you do not hear the motor hum than try to unplug the machine and leave sit for 30 min and than plug it back in and than see if it now tries to run but if no motor sound than youwill know that the motor has either failed and needs to be replaced or that there is a problem with the thermal fuse that is on the controle panel behind the start button ok
i can help if there is any more issues that you need help with.
Hope this is very helpful for you.
Best regards michael
Posted on Dec 19, 2009
  • 414 Answers
SOURCE: Dryer runs but doesn't heat
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Posted on Jun 21, 2011
tbirdfan1
  • 3051 Answers
SOURCE: I have a duet electric dryer GEW9250 about 5 years
Hello there and thank you for choosing fixya
To tell you the truth i dont think the contrlole panel was the problem the control panel rarly goes out here is a list of the most common things that go out and are a lot more cheep to replace
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Aug 05, 2011
KevinWhite
  • 1902 Answers
SOURCE: Admiral gas dryer model#adg7000aww: rotates but
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
Posted on Aug 07, 2011
Freightliner columbia wont blow heat into cab have replaced thermostats and heater core blend doors work heater core gets hot and blower works but air from vents only gets to 80 deg
The air from the heater core will be as hot as the coolant temperature of the engine. 80 Degrees is the opening temperature of the thermostat and that will be where it remains until the engine starts to work or the ambient temperature rises.
Thermostats come in a couple of different opening temperatures so check around for one that opens around 85 degrees if you want hotter air in the cab
Another point is to close the recirculating vent door to the cabin as the heater core is trying to heat fresh freezing air if it is open
Jan 09, 2015 | Cars & Trucks
A/c not changing to heat
The engine is overheating! Check the coolant level to be sure it is full. Other checks will then be to make sure the water pump is working. With the engine overheating, you are not getting coolant moving through the engine, or your heater core for that matter. If the coolant level is good, I would go to the water pump/thermostat next.
Dec 10, 2011 | 2001 Oldsmobile Aurora
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
Candy tumble dryer is rotating but no heat coming through
your heater is broken or one of the one shot thermostats has tripped. it needs a new heater fitted. but before you break another make sure that the filters are clean, the machine has an adequate gap between it and the floor and the exhaust is unrestricted otherwise you will break the new heater too
Nov 21, 2008 | Candy Dryers
Outside unit clicks while thermostat auxiliary light flashes
Sounds like the compressor starting relay or capacitor is defective. When the compressor could not start, the electric heat came on to satisfy the heat requirement and causing the emergency heat light to come on at the thermostat. This light warns you that electric heaters are energized. And they use a LOT of electricity! Call a different company for service. And do it soon.
Ray
Nov 16, 2008 | Ruud Handler Air Conditioner
Flashing warning light comes on after about 30seconds
If the heater is bad the machine will never reach the temperature so the light will never be on.Make sure if you open your steam knob to have some water coming out and feel if the water is warm or cold.Some machine have a thermostatic switch inside for protection..I don`t know specifically your machine but they all work about in the same way.
Jun 10, 2008 | Ariete Coffee Makers & Espresso Machines
Power light on, no warning light, doesn't heat up at all
Your resettable thermostat turned off the high power heater circuit and the red warning light. The heater got too hot when the boiler became empty of water. This is to keep the heater from burning out if the boiler becomes empty. To reset the thermostat, turn the micro casa a leva over. There is a yellow plug near the center of the bottom which is easy to pry out. Stick a screwdriver, pencil, toothpick, chopstick or whatever else is lying around into the hole and gently reset the thermostat button. You will hear a click when it resets. You are then ready to go.
Jan 04, 2008 | Elektra micro casa a leva S1CO Espresso...
Dryers Logo
134 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
