I have problem when i upgrade i get upgrade hit any key to exit
How do i change the font size on the vx 520
http://www.1nps.com/content/images/product_docs/Verifone_VX_520_Installation_Guide.pdf
Nov 21, 2014 | VeriFone Vx 520 Dial 160Mb, New
Power comes on no video, monitor works
Try hitting the F8 key or what ever is the key for safe mode, or try F11 for boot menu, if boot menu shows boot to hard drive.
If these don't work, unplug the PC, then hold the power button until the lights flash or hit again and make sure lights don't flash on.
remove the side cover, touch metal, then remove the little round battery for 5mins, replace, plug in, hit power, not hit the delete key and try to boot into the BIOS, you will need to set the date and time. then move to exit and save changes and exit.
Mar 14, 2013 | Dell OptiPlex GX620 PC Desktop
What is the PhoenixBIOS Setup Utility
The bios setup utility is what controls the computer. It allows you to set the date and time, identifies the devices (hard drive, dvd drive, etc). components and configurations (memory, cpu speed, etc).
You get out of it by looking at the screen and hit the key that it says to hit to exit out. If you are not sure about what you did normally you can hit a key that will allow you to exit without saving any changes you made.
May 20, 2012 | Toshiba Satellite L455D-S5976 Notebook
I have a Pure One classic radio.When turned on the display screen reads "upgrade (reva) press any key to exit)I press a key but the same screen comes up again.Cannot get any station to play and can...
I have the same problem, and no real solution, although I do find by hitting one of the keys several times in rapid succession, then pressing the standby button, the radio does tend to come on.
Really irritating, though, and I'd love to know how to fix it for good. Good luck - and do let me know if you find a solution.
Gilly
Dec 06, 2010 | Pure Digital The Bug DAB Radio
My laptop won't turn on. Blank screen, green on/off botton blinks. Tried forcing it off, but nothing hapens. Tried taking battery out and pluging it in, still no change.
it's fell asleep,switch it then the minute you've hit the power button start tapping the F2 key unit you get into the bios settings.
in there you will see a set of tabs across the top the last one being "EXIT" useing the arrow keys go to exit
hit ENTER then move down to GET DEFAULT VALUES/SETTINGS or LOAD DEFAULT VALUES/SETTINGS
Which ever & hit ENTER select yes then hit Enter again then move back up to exit saving changes or
save & exit the computer will shut down & reboot.
if not download & check the manual : click here
Nov 22, 2010 | Acer Aspire 5520-5908 Notebook
After starting Zebra S400 the printer makes an automatic calibration each time, spending 2 blanc labels on it. How do you turn off auto-calibration? Already tried the Zebra.com official site, without luck.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of MEDIA POWERUP (if not, repeat previous steps)
Hit the + sign until you get to NO MOTION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Sep 20, 2010 | Zebra Stripe S400 Label Printer
How do you reset preventive maintenance message?
Hit P * C*
press 20
hit start
press 01 or 1
hit start
hit CA to exit
This is the "Maintenance Count Clear" sequence.
Aug 12, 2009 | Sharp AR-168S Copier
Starveiw box three
Hit MENU Key in 1570 Should open a secret menu Turn the KEY EMU to ON go into nagravision and key in the new codes useing the remote control then hit ok to store
Exit back onto the main screen (press exit x2) Wait for a few seconds for the box to update itself And away you go! hope that helps
Mar 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Nokia n95
That circles mean the progarm is running. The n95 keeps apps running in the backroun. To see the apps running u can go in to the menu and look for the circle, or u can press and told the menu key this will give u a list of the apps. U can also exit the programs from this by hitting the clear key. If you press the end key or exit the progarm with out hitting the exit button then it will keep running.
Jun 15, 2008 | Nokia N95 Cellular Phone
Changing Time
Hey peoples this worked for me :)
On the main phone
- hit the "PROGRAM" key
- then key in **
- it asks for a password key in 1234
- then key "NEXT"
- then key "ENTER" (this is to set the date)
- then key "NEXT" (this is too set the time)
- once the time is correct hit the "ENTER" key at the bottom of the phone.
Mar 09, 2008 | Panasonic KX-T7630 Corded Phone
132 people viewed this question
 Grubhead
Grubhead
