How do i fix if my computer has power but no display
    Brigadier General:
  • 3,400 Answers
1.CHECK THE VGA-CABLE.
2.CHECK THE VIDEOCARD CAN BE BROOKEN
3.CHECK THE MONITOR,TRY WITH A OTHER MONITOR.
4.THE VGA-CABLE SHOULD BE SEATED TIGHT AND FIRMLY,IF
POSSIBLE TRY A NEW ONE.
Posted on Mar 27, 2015
Display and backlight using my battery up how do I fix this?
The display and backlight are the biggest users of power for any computing device. You can lower the display brightness and on some even lower the backlight intensity to conserve power, but this will have an impact on your viewability.
Sep 18, 2016 | Tablets & eReaders
My computer will not start, when I turn the computer on it has a blank screen. How can I fix my computer?
try to go BIOS AND CHECK THE DISPLAY,IF THE DISPLAY IS OK THEN TRY BELOW
1.check the power connection of the computer
2.check the power connection for monitor or any loose connection.
still nothing is coming do the next.
turnoff the computer completely,disconnect the powercabel,disconnect all the external devices press and hold down the power switch on the tower for 30 seconds,reconnect the power restart the computer.
Sep 16, 2010 | Computers & Internet
Tower turns on but nothing appears on monitor
You need to follow the easy steps and get rid of it
1. Make sure your display (moniter, CRT, LCD, screen, whatever you prefer to call it) is plugged into a wall outlet or power strip and powered on. Also ensure that it is securely plugged into the back or bottom of your display. Many displays do not have removable power cords, making them more prone to shorts and other damage. Check your cable to make sure it isn't damaged.
2. Make sure the power strip or wall outlet that your display is plugged into are functioning by plugging another electrical device, such as a lamp, into it and switching it on.
3. Check the connection between your computer and your display. Make sure that it is completely plugged into both as well as fastened with the attached screws.
5. To double-check any possible cable problems, if at all possible, swap out the screen's power cord and the cable connecting your computer to your display.
6. Swapping out your display is also a good way of narrowing down the problem. If you get the same result with a different display, then you can be near positive the problem is something in your computer. If switching displays fixes it, then the culprit is a faulty display.
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the monitor but in the computer.
Read more: http://www.brighthub.com/computing/hardware/articles/12648.aspx#ixzz0s9UQmWub
Please rate me if this solution works for you
Thanks......Have a great time
Jun 26, 2010 | Gateway 504GR PC Desktop
Describe your Epson im- 700 pos machine com portProblem Hi, We have IM -700 POS now its getting problem with printer and display. Showing com port error code 1001 pls any body can help
If you are getting display problem then
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the moniter but in the computer
May 18, 2010 | Epson POS TMT88IV Thermal Receipt Printer
Imac g5 17 gets some power but no display
Assuming you have the model with four diagnostic LEDs, the lack of LED-3 indicates that the computer and the LCD display are NOT communicating. This LED should be ON when the computer is turned on and video signal is being generated.
The first solution is to reset the PRAM (hold command-option-P-R after the boot chime until you hear another boot chime). If video does not appear, then power down the computer and reset the SMU by pressing the SMU button ONCE ONLY. (The SMU button is located just south of the fan housing and is the button further away from the fan; the other button is a power button.) If this does not fix the video, the next step is to remove the optical drive. If this does not fix the video, put everything back together and attach an external display using the dongle supplied with the unit. If the external display fails to work, you have a logic board problem; otherwise, you have an LCD panel, inverter, or cable problem.
Mar 30, 2010 | Apple iMac G5 Desktop
How to fix timing error reset 1680x1050
your cpu is with internal display card will not support over 600x800 YOU have to attatch external AGP card in the slot then change resolution then computer will ask do you want to keep these settings say yes but computer is not showing display then press f 8 contineusly after power on and when safe mode will come press enter
Nov 20, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
