Question about Welch Allyn TM 262 AUTO TYMP
The controls lock up and will not switch from audiometer mode to tymp. mode, but ONLY when the printer is used. What could be the problem?
Printer went crazy and started printing, printing, then controls locked up.
How do I get my Eltron LP2042 into ELP mode?
After loading labels into the printer, place the power switch in the"0"(OFF) position.Press and
hold the FEED control while placing the power
switch in the"1"(ON) position.Release the
FEED control when the printer starts feeding
labels.The POWER indicator will turn off and
then switch toGreen while the adjustment is
being made.The printer will advance 3-4 labels
while performing the adjustment. When the ad-
justmen tis complete,a status summary label will
be printed and the printer will be placed in
Diagnostic Dumpmode.Tap the FEED Control
once to switch theprinter back tonormal opera-
tion. When the indicator switches to Green, the
printer is ready for use.
May 08, 2014 | Zebra Eltron LP 2824 Thermal Printer
When I attempt to print the data and ready lights are on, but soon after it sounds as though it will print, the "Alarm" light appears, and printing stops.
Go into Test Print Mode
The printer incorporates various test print modes.
Select the test mode you want to use following the steps below;
(1) Turn off the power switch of the printer and check that the front cover is closed.
(2) Turn on the power switch while holding down the control panel button. Press the button
until the Drum LED comes on.
The Drum LED illuminates to indicate that the printer enters into the test print mode.
(3) If you want to execute the test print, release and then press the button again when the
Drum LED comes on.
or
Push "alarm" button : The printer is restored to the factory setting and permanent fonts and macros are cleared.
The printer returns to the ready status after
printing.
If it does not reset, replace the main PCB.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Brother HL 1440 Laser Printer
Red Alarm light (and all others) flashes, does not print. Closed properly. Seems to be a small amount of toner left in cartridge.
Drum LED comes on.
or
printing.
Thanks, Joe
Feb 22, 2011 | Brother HL 1040 Laser Printer
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
HOW DO YOU CHANGE THE CHARACTER PITCH
You have not specified which printer you are using.
1. In a serial printer having a displaceable printing head and being selectively operative in a setting mode for setting a variable character pitch and in a normal mode for effecting a printing operation according to the set character pitch: a plurality of manually operable switches each having assigned thereto a normal function which is performed when the switch is operated when the printer is in the normal mode and having assigned thereto a setting function which is performed when the switch is operated when the printer is in the setting mode, at least one of the switches having a setting function which effects selective displacement of the printing head to one of a plurality of predetermined positions each corresponding to a different character pitch; means for producing character pitch data effective to specify a desired character pitch according to the selected position to which the printing head is selectively displaced; and storage means operative when the printer is in the setting mode for setting therein the desired character pitch data for use during a printing operation of the printer in the normal mode.
2. A serial printer according to claim 1; including controlling means for controlling the serial printer to effect changeover between the normal mode and setting mode.
3. A serial printer according to claim 2; wherein one of the switches has a setting function which enables the controlling means to set the setting mode.
4. A serial printer according to claim 3; wherein two of the switches have setting functions which effect selective displacement of the printing head in opposite directions.
5. A serial printer according to claim 3; wherein one of the switches has a setting function which enables the storage means to set therein the desired character pitch data.
Jan 28, 2010 | Electronics - Others
Printer LBP 2900 sends an error code E 100 0000
Check BD detection PCB cable.
Replace Laser Scanner
Replace DC controller PCB
Jul 14, 2009 | Canon imageRUNNER 330 Printer
Toner Saver.
Using the Toner Save Mode
The Toner Save mode allows the printer to use less toner on
each page. Selecting this option will extend the life of your toner
cartridge and reduce your cost per page, but will reduce print
quality.
There are two ways to enable the Toner Save mode:
From the Control Panel
Press the Cancel button on the control panel. The printer must
be in Ready mode (On Line/Error green LED is on).
• If the Toner Save LED is on, the mode is enabled and the
printer uses less toner to print a page.
• If the Toner Save LED is off, the mode is disabled and the
printer prints in the normal mode.
From the Printer Properties
You can also enable the Toner Save mode in the Graphic tab of
the printer properties. For details, see Software User’s Guide.
Jun 30, 2008 | Samsung ML 2010 Laser Printer
Lexmark 1532
If the Operator Panel is locked. (Menu's disabled) you need to enter Config Mode to enable the operator panel. Press and Hold the > right arrow and down arrow buttons while powering on the printer. Once in configuration mode scroll to Panel Menu where you can enable it. Exit Config Mode or just power the printer off and back on.
Mar 28, 2008 | IBM Infoprint 1532 Laser Printer
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Welch Allyn TM 262 AUTO TYMP Logo
698 people viewed this question
Top Welch Allyn Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Welch Allyn Toy Expert? Answer questions, earn points and help others
