Question about GE Refrigerators
HOW DO I PUT A GE 31949 OR 3977 SIDE BY SIDE REFRIGERATOR INTO DEMO MODE?
  • GE Master
  • 473 Answers
Those numbers are not good model numbers. If you have the owners book it should tell you or go to GE.COM and read the manual off their site. It probably just a matter of pressing 2 control pads at the same time for a set number of seconds.
Posted on Apr 03, 2015
SOURCE: ge profile refrigerator
my refrigerator model #gss221fphbb not cooling
Posted on May 12, 2008
  • 1314 Answers
SOURCE: Demo Mode
try unplugging it then plug it back in
Posted on Jul 19, 2008
  • 4 Answers
SOURCE: Side by side GE refrigerator freezing food in refrigerator.
The unit is having a damper control issue. In the back of the refrigerator there is an assembly that is in the center at the top. It connects to the freezer side. The damper is broken, cracked or has an obstruction. Check this and see if it is the problem.
Posted on Jan 09, 2009
rogrrabbit
  • 986 Answers
SOURCE: We just purchased a ge profile refrigerator today,
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Posted on Jun 14, 2009
woodchuck789
  • 4059 Answers
SOURCE: my ge profile side by side refrigerator's
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Oct 20, 2009
Tip
How to reset it out of demo mode
If your not getting any response out of your control pane you will have to do the following
The refrigerator may be in Demo mode which disables the compressor to save electricity when the refrigerator is on the showroom floor. To cancel Demo mode, press Freezer and Arctic Select Zone buttons for 8 seconds. You will hear a chime.
on Dec 25, 2008 | Samsung RM255LASH Side by Side...
It is showing a code: OF followed by oF
Your refrigerator is in demo mode. For a detailed description of how to get refrigerator out of demo mode, press the two button on the upper left side of display for 3 to 5 seconds or until the OF dissapears. If your refrigerator does not have a display on the front side, do a search for "how to take samsung refrigerator out of cooling mode/ demo mode" and it should give you several options available for your model of refrigerator.
Hope this helps
Mar 03, 2015 | Samsung RS265TDRS Side by Side...
How to put refrigerator into demo mode?
Hello friend, that's a great question!
In order to put your Frigidaire refrigerator FGHB2866PF into demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. Hope this information helps. -Matt
Jul 21, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Demo mode rs255sl
This function is for a display purpose on the floor of show room or store.
1) Mode ON/OFF
1-1) For the exhibition mode, press Power Freeze and Freezer Temp. buttons simultaneously for 8 seconds until a
“ding-dong” sounds.
1-2) Press the same time buttons again for 8 seconds to cancel this mode put with a “ding-dong” sound.
2) Operation
2-1) Most of the system function except the compressor operation are working properly.
2-2) There is no defrost cycle in this mode.
Mar 21, 2010 | Samsung RS265LBBP Side by Side...
How to turn off demo mode
How do you turn off the Demo mode on the electrolux side by side refrigerator??
Jul 09, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Resetting the demo mode
turn off with OFF sw.
Press WARMER / COLDER sw for 5 seconds
While maintaining warmer / colder turn ON with ON sw.
SHOULD NOW TURN ON
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Floor model will not come out of demo mode.
If following dirctions from your owners manual does not do the trick. I would call for a tech to look at it. Every thing is control by dispenser board on a PSS26P
Jul 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Demo Mode
Jul 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge profile refrigerator
May 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
