Hi hisense aircon hideaway is giving error code No 51. What can be the problem?
My 2001 mercedes S320 blows hot air through the side vents when I turn on the aircon. - Resetting gives me error code 1418. Can anyone HELP?
It could be a failure in the solenoid valve of the heating system that is leaking hot water in the aircon system.
May 10, 2017 | Cars & Trucks
Hisense tv
so whats the remote you have there?
Oct 23, 2008 | Hisense TA42P40M 42 in. Plasma Television
Hi, I have Hisense 50K23DG. It has no sound, no picture and 5 and half or as 6 red blinkings. Do you know any error code for this Hisense?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 20, 2016 | Hisense Televison & Video
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
Airtech aircon gives an E4 code and then goes off = what causes this and how do I remedy it
Two days ago we had an Air tech Airconditioner installed and it is showing an error FE what is this pls?
Sep 04, 2010 | Heating & Cooling
Hideaway brain unit on my kenwood KVT-617 doesn't work
My KVT-617 display unit was stolen out of my dash, but they neglected to snag the items under the rear seat: the "brain" hideaway unit, the HD radio receiver, the 10 disc CD changer, the navigation unit, and the powered subwoofer.
Everything was replaced via the insurance except the sub because the new system was not compatible with the old components. Make me an offer on the items you want!
timsterp99999@att.net
May 29, 2009 | Kenwood KVT-617DVD Car DVD Player
ERROR CODE 5 on Hitachi 51 inch
You have a bad convergence circuit, very common problem. A good repairman will run you around $400 to do the repair.
Let me know if you have more question.
Tim Nolan
Experttv@comcast.net
Oct 12, 2008 | Hitachi 51F59 51" HDTV Projection...
Hitachi Aircon
According to the error codes for hitachi, there is no AO code. The codes on the code list are all numeral.
Jan 09, 2008 | Heating & Cooling
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
