Unit will turn & say heating but freezes at that point will not go any further?
    Top Expert:
  • 45,301 Answers
Call a service man
Posted on Mar 27, 2015
Air conditioner outside fan does not turn off
Is the compressor shutting down and fan is not??? How about the blower, is the coil freezing? Need to check the contactor on the outdoor unit, 240 volts hurts, please use caution. If not confident as to what you are doing call a professional. If need be turn off breaker, you do not want the coil freezing inside!
Aug 19, 2017 | Heating & Cooling
Tip
Staying in hot water
With water rates on the rise, it is costly letting water run at a remote hot water faucet. It makes more sense than ever to insulate exposed hot water pipes in the basement with the foam insulation that's split lengthwise.
As an added benefit, freezing pipes can be avoided during power outages. The hot water pipes freeze sooner than the cold water ones because the freezing point of heated water is closer to 32*F than the freezing point of cold water. Cold water has a depressed freezing point due to dissolved minerals from municipal water treatments. Water that's been heated has fewer contaminants, hence less freezing point depression!
on Feb 28, 2010 | Washing Machines
I submitted a ? Earlier in reference to the igniter on my Coleman central unit w model PAC036H1021A.. My unit stopped blowing heat and was blowing cold air only in the house. It stopped last night and I...
It sounds like you may have electric heat. With that being the case and your description of a burning smell indicates an electrical problem. Since you did get it to start heating it sounds like a possible heat relay problem. I have also found burned connections and I was able to repair them and get the heat strips working again. If you know an air-conditioning and heating technician or electrician you should try to get assistance. The voltage in these units is dangerous and one mistake could only make things worse.
Feb 13, 2015 | Coleman Heating & Cooling
Heating Problem
Could you explain this further. Are you talking about the heat strip located behind the gasket in the freezer area to keep the door closing against the gasket from freezing or the heat that naturally occurs from the operation of the unit that blows the air from underneath the refrigerator.
Feb 03, 2013 | Refrigerators
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
Model no idf125 Dishwasher fills with water then sounds as if it is about to heat the water but then stops and keeps repeating this and will not go any further????
Hello, On your unit do you see a flashing green light? Usually if the unit is unable to heat it would tend to point towards the unit having an issue with the heating circuit whereas either the heating element has a short in it or a thermister has shorted in the unit. If you happen to have a multimeter you can perform an ohms test, or a continuity test on the element and the thermister as well to assure that these are functioning properly. If you are unable to perform this test with a multimeter I would suggest that you call a service technician to repair your machine. If the element is unable to produce heat in any dishwasher the unit will just fill and then stop and not go any further into the wash cycle due to the water is unable to heat. If you have any further questions message me back. I await your reply.
Thank you,
Rick
Oct 06, 2011 | Indesit DF125 24 in. Built-in Dishwasher
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
Wired wrong
in order to correctly wire the unit you must have 6 wires outside and a thermostat that will be able to have a aux heat setting if you have further questions tthen email me @ hvacredneck@yahoo.com
Jan 06, 2010 | Heating & Cooling
Freezes on start up
my usual faceatious comment to freezing GPS is to put a match under them to thaw them out.
But on a serious not i would suspect that your maps have somehow corrupted and need reinstalling
Jun 28, 2009 | Magellan Roadmate 1200 Car GPS Receiver
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
