Question about Dishwashers
Well in dishwasher is full.have tried Mr.Muscle drain gel and boiling water to shift it but to no avail
    Top Expert:
  • Dishwashers Master
  • 47,720 Answers
Gonna have to call a serviceman dirty messy job ahead for him
Posted on Mar 27, 2015
Testimonial: "My partner sorted it, thanks for your comment!"
Cleaning insrtructions
Gp to a restaurant equipment store or a food broker type place, or I can ship the product to you via UPS, but there are prodcuts developed specifically for cleaning fryers out, like Mr. Muscle, Degreaser, etc. You would fill your fryer up w/water, add the solution, like a packet of Mr. Muscle, and continue to boil the mixture for some time in the fryer.... After it's boiled for some time, use a fryer brush on your heating elements, etc, which you can also buy at a local store or I can ship one to you. When the fryer is clean, you will drain the mixture out and rinse several times. You want to make sure you get all the soap residue out of the fryer or it will destroy your oil after you add it in and try to cook with it...Rinse several times, then add your oil and you should be ready to go. You can also drop your fryer baskets in the mixture just like you are cooking and the boil out product will clean them too.. Be sure to drop them again as you rinse the whole unit out.. Hope this helps. Buy a couple of green pads too, and they should help you with any outside baked on stuff
Good luck,
Susan
REO
Dec 12, 2011 | American Range AF45LP Deep Fryer
I just need to know how to completly clean the bottom of my imperial fryer
Are you talking about the actual burners? They make a L shaped brush that you can use to get around the burners themselves, and a quick tip is to clean the fryer warm.... Once you heat up a griddle or fryer, the cleaning gets substantially easier. They also make either liquid or dry powder cleaning additives, which also help with the cleaning... Once cleaned, make sure you rinse all the soap residue out of the frypot, as that will help to quickly break down your oil, once that new oil is heated up. Another tip is to ony turn the temperature up to 325, not 350, as that also helps to break down your oil. Keep in mind, no matter what yu do, your fryer will never look clean again.... Even the clean, used ones look alittle used after some use and never look shiny new again. If you need any of the cleaning solutions, I do sell them and would be happy to ship some to you... Our individual packets of liquid Mr. Muscle cleaning solutions run $1.95 each and for a 30-40 lb fryer, you need two per cleaning. The directions says to drain oil out and rinse to clean out loose soils, fill w/'water to oil fill line, and get water boiling. You add the Mr. Muscle while filling w/water.... Boil at about 225 temperature for 10-30 minutes. (225 degrees keeps it from boiling over). While it's boiling, gently use a fryer brush or scraper to remove baked on soils. You can also buy the powder version, which is $11.95 for a 9lb jug... Fryer brushes are $24.95 and can withstand alittle of the high heat.... I stock all of these items and can ship to you, if desired. Try this anyway, whereever you end up buying your products and this should work for you...This is how we clean the dirty deep fryers we get in and we've never had any trouble. Our phone number is 888-542-5959, and we are Restaurant Equipment Outlet, Cincinnati, Ohio. We sell new/used equipment, furniture, smallwares, just about anything you need for a food service business.
Thanks, Susan
Jul 18, 2011 | Imperial IFS40 Deep Fryer
The dishwasher sounds like it was blocked and the light flashes. We have put Mr Muscle unblocker down and the water now drains from the washer, but it still makes a deep sound and doesn't run through a...
This would indicate a failed wash motor. You would need to order and replace the motor to fix the issue, which is easy to do. You can purchase the part from the link below by toying your model into the search box.
Appliance & Refrigerator Repair
Mar 23, 2011 | Whirlpool Dishwashers
It leaves about an inch of water after finishing, Hoses seem clear but the pump seems stiff to turn when i take out the filter, how can i get to the back of pump to clear it. do i need to turn the...
I WOULDNT TURN IT ON ITS SIDE IF IT HASNT FULLY EMPTIED. I WOULD TRY A DILUTED SOLUTION OF Mr MUSCLE DRAIN UN-BLOCKER. THEN RUN ON A FULL CYCLE STRAIGHT AWAY.
Oct 01, 2010 | Dishwashers
Our dishwasher is retaining water in the base and not cleaning our dishes fully what is the problem?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Aug 15, 2010 | Frigidaire Gallery FGBD2451KB Full Console...
Can I use Mr Muscle Sink and Drain Foamer to clear a pipe that connects my shower to my Saniflo, which is also connected to a washbasin and toilet?
You can try using it first (Mr. Muscle Sink and Drain Cleaner). It it will clear the pipeline, that's ok. Otherwise,
you have to use a mechanical declogging tool to clear it.
Nov 18, 2009 | Plumbing
Water will not drain out. still water in the bottom when it stops.
there could be a cloge in the draineg tube, look in to it, first try to pick out with some wire all of the food left over's from the machine it self (UNPLUGE THE MACHINE FROM THE ELECTRICITY) or use some comercial drainers like mr muscle or something like that
cheers
Oct 31, 2009 | Dishwashers
After I run the dishwasher, water stands at the bottom and it smells. I have had the dishwasher for five years. The washer seems to be working properly it's just that water stands at the base of the...
no it's not normal, you are probably having some cloge in the drain pipe, you could try with a pice of wire to pick it up or hose it down, or use some comercial unplaguners like mr. muscle or something like that, i think that this would do the trick
Oct 30, 2009 | GE Nautilus 24" Built-in Dishwasher
I have started hearing a gurgling sound in my diswasher air vent when I run water in my sink. Why has this begun happening? I have an /estate dishwasher Model TUD7000Y-0
Sounds like your waste water drains could be backing up and pushing water back into the dishwasher.
Firstly try pouring Mr Muscle sink and plughole un-blocker down the sink and leave overnight next morning pour boiling water down the sink and your pipes should be squeaky clean. Hopefully this will improve the flow and prevent gurgling!
Feb 21, 2009 | Miele 24 in. G870 Built-in Dishwasher
Figidaire Dishwasher ModelFDB65BRAC1
I just had this problem with a zanussi dishwasher - I opened it this afternoon to find the bottom full of water - luckily not deep enough to flood my kitchen when I opened the door. I determined that the sink drain was clear (ran water, could hear it going down the drain outside), so the problem had to be in the dishwasher or drain hose. I poured just a little mr muscle sink & plughole unblocker in the bottom of the machine where the trap is, left it about 30 mins as per instructions, followed by a little boiled water - no difference. Scooped out the water, removed the filter (the big round bit, not just the trap that you pull out and empty) and scooped out till I could see what appears to be the out pipe. Thought what the heck and ran a rinse cycle - no dishes, no detergent and lower tray and arm thing removed for convenience. Water drained just fine, ran a second rinse cycle which got rid of the suds from the plughole unblocker. I now have an extremely clean and sparkling dishwasher and am about to run a load of dishes through it.
I hope that my post is helpful to you, I don't know if all the steps are necessary, it may have been a freak occurrence that would have gone away with a simple rinse cycle. It may of course be a problem with the pump on yours, I was hoping that wasn't the case on mine, and I had lots of old towels on hand in case water came out when I opened the door. But it's possible your machine has the same problem as mine and that this info works for you, I hope that is the case.
Sep 19, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
