Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
No working i bought a honeywell he360 a , in first time that was working but the problem is no want to working anymore
0 characters
1 Points
I have honeywell humidifier HWM340. Just 2 months old Now i see the Autoshut off system doesnt work. When no water left in it. The red light comes on indecating empty. But humidifier doesnt stop. Keep...
I wouldn't mess around with trying to fix it myself if the item is still under warranty. If you are smelling burning, and safety mechanisms aren't working, I'd be very careful about continuing to use it.
Do you still have your invoice? At only 2 months old, the unit shouldn't be malfunctioning like that. Best thing to do would be to take it back and exchange it for a new one. If the place you bought it from won't take it back, then call Honeywell directly. Honeywell should cover either fixing it or exchanging it under warranty.
Mar 26, 2015 | Honeywell Humidifiers
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
Nov 10, 2013 | Honeywell HE360A1027 Whole House...
Fan and water run continuously on he360
I'm not sure what wiring option did you use, but looks like you did not include pressure or sail switches... When the furnace blower/fan is off it should open the 24volt circuit and close the water valve (normally close) and turn off the fan. If you can post more wiring details maybe pictures or hand sketch I'm sure problem can be fixed in the few minutes.
Water constantly running in honeywell humidifier
I has the same problem with my HE360 unit. The unit was in fact miswired. The head unit red wires were connected directly to the blue solenoid wires, and activated the solenoid without any signal from the humidistat. As soon as the unit is plugged inn, the water starts running without any signal to the unit. If your unit is miswired, the soleniod blue wires need to be cut and connected to the red crimp connectors.
Mar 11, 2009 | Honeywell HE220A1019 Whole House...
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Honeywell chronotherm III air conditoner
I had that last night. I turned off the unit for a couple of hours and it came back on and ran and cooled. I have no friggin' idea if it will work but it got us through last night.
Jun 05, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
Top Honeywell Humidifiers Experts
Barrett Palumbo
Barrett Palumbo
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
