Question about Epson Stylus CX6600 All-In-One InkJet Printer
I only need to print black
My cartridges were all low or 20 - 30%. Since I am only currently needing to print in black, I only replaced the black cartridge. Now the ink level says black is 100%, but the pages don't print. the printer runs as if it were printing, but the pages mcome out blank.
  • sfixya Dec 19, 2007
    My printer wants the yellow ink to be replaced. I can't find a way to override the error message and just print in black. I tried to re-set the machine with the menu buttons to no avail.
Ggxddfft yery
Posted on Dec 31, 2007
Change the cartridge
Ad hohumincali
as all the cartridges are NOT empty, Head Cleaning (repeatedly) may solve your problem.
Posted on Dec 22, 2007
I have a HL4040CN copier. When the message comes up that ink is low, how can I tell what color ink cartridge needs replacing
You're just going to have to keep printing until you see which cartridge is getting dry. It'll be either the black one or the colour one. This way you won't buy the wrong cartridge. If you print black text and it starts to come out grey then it's the black cartridge that needs to be replaced. The same with colour, if the picture looks faded then you'll need a new colour cartridge.
May 11, 2011 | Brother Office Equipment & Supplies
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Magicolor 2400w color low. how to allow printing in black without need to replace the color toner? I mean, i only need to print in black only so at the moment i can ignore the color low warning.
its not possible as whast u required.because all the cartridges should be shown full for printing whether you use the colour or dont use.
but you can get your cartridges refilled at any local stationery shop or at the local refilling center.
and this will not cost u as new cartridges.its exactly less then half cost of new cartridges.
thanks.
Oct 13, 2008 | Konica Minolta magicolor 2400 Laser...
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Low black ink - can not print at all
Most epson inkjets that use separate colour and black cartridges will not print if either the colour or the black cartridge is empty. The printers come with cartridges when new but they are only part full and more ink is used up filling the printer reservoir when first starting up. Replace your black cartridge and you should be able to print. barrie60s
Jul 24, 2006 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
