Question about Epson STYLUS PHOTO T60 INKJET PRINTER
Printer epson t60 the red light are always transferring to sides
After i refilling an ink and head clean for 4 times, what should i do to fix it coz we need to fix it now and it reqiures a service..
    Problem Solver:
  • 19 Answers
You can free download epson service adjustment program friom www.epsonhp.com
Posted on May 14, 2019
    New Friend:
  • 57 Answers
You need to reset waste ink pad counter by adjustment program for epson t50 t60 printers
Posted on Mar 27, 2015
SOURCE:
It won't print in black, after refilling the cartridge.
try sucking from the bottom with a refill clip in order to remove the air that is in the cartridge and holds ink in the sponge
look in this video for a success refilling
http://www.youtube.com/watch?v=MPi2GqJg5QM
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Dr Print
Apr 30, 2010 | HP C4680 All-In-One Inkjet Printer
Canon pixma MP 130 waste ink absorber
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Jan 29, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Wont print black, just color. I replaced all ink cartridges and
hi this is kamal..
hey my dear friend if u have replaced all ink so pls change ur black cartridge coz after 2 or 4 refilling it won't work... so pls change
thanx for choosing fixya
regards
kamal singh
Oct 09, 2009 | Brother Multi-Function Center MFC-240C...
Why wont it print red after i got it refilled
the ink is not compatible using refilled u need original ink for this printer brand...good luck..
Jun 25, 2009 | HP DeskJet F380 All-In-One Printer
How do you fill empty ink carteges
if u want a working printer which would last for a long time ... do not refill a cartrige coz the kind of ink used in the refill and the ink used by the company are of different quality .,.. the ink in the original printer doesnt harm the head of the printer but the refill ink just makes a coat on the printer head and damages the printer head the original cartriges are no doubt expensive but ur printer is worth
May 07, 2009 | Office Equipment & Supplies
Black ink will not print
The ink on the print head is dry and it is preventing it from printing.
I do my own refill so I buy a refill kit, in it, has 3 bottle of inks and a bottle of cleaning solution. The cleaning solution I use to clean the head.
A place that refill in should carry some kind of a cleaning solution that you can use.
I hope this help you
Mar 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer Ink wont work!
HI~ First Check your ink..if you using compitetor ink or CISS ink , Remove The Rubber that are in the Ink Cattridge there, Coz When the print head **** the ink from catrige with pressure it will stuck the print head from spraying the ink out...  After Remove those rubber that are on the ink catrige you need to clean it to release those presure that build coz of those ink catrige build....                                                   If it dont work your print head need to be purge and you need to get in Maintenance mode...then coz you are using generic ink it maybe have spray to other part of the printer the ink Sensor is very close to ink absorber and the Generic ink usualy leak coz the design are not good but it is cheap and you need to know how to use it...
Dec 18, 2008 | Brother Multi-Function Center MFC-240C...
Low ink level after ink refill prohitting print function
Click on your lexmark maintenance tools and click on install new cartridge. This should fix your problem.
Mar 29, 2008 | Computers & Internet
No black print outs
Run the software cleaning utility (almost always accessible from the printer) in order to fix a clog. Replace the ink cartridge if the clog cannot be fixed or if the cartridge is almost empty. A way to physically clean the clog is using a q-tip dipped in rubbing alcohol and wiping it on the printer cartridge head.
Jul 23, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson STYLUS PHOTO T60 INKJET PRINTER Logo
455 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
