I have problem with my scanner.
when I want scan whith that show this message:
cannot communicate with scanner
cable may be disconnected or scanner may be turn off.check status.scanner driver will be closed. code : 21550
please help
-   I have got MP180 and whenever i try to scan pics i get this error:21550,
I have uninstalled/reintsalled the drivers, chnaged the usb cable, restarted the PC/Printer...but no joy :-(-   LC1982
Jun 15, 2008
-   I have problem with my scanner. when I want scan whith that show this message: cannot communicate with scanner cable may be disconnected or scanner may be turn off.check status.scanner driver will be closed. code : 21550 please help-   vijaygupta
Mar 26, 2008
-   same problems. have reinstalled unplugged etc.. tried trouble shooting help section.-   Guest
Jan 01, 2008
-   i have done everything, turn ff and on, cancell all pending tasks of the computer, but when I want to scan a document, the same thing appears again and again error 2,155.0 can not comunicate with the printer. I have also check, plug and umplug the wire of the printer, have restarted my computer and still I am not able to scan my document, please advise-   johnbarbero
Thsi usually happens with canon printers and scanners jsut re-install the driver...I wonder when they will fix it..This happens each time you disconnect the cable and then put it back..
Comments:
Nov 17, 2007
- sindy u wont get any more help when u marked it as in-appropriate...read more abt the ratings.. http://www.fixya.com/RankingExpln.aspx change it or is case closed.. eagle!
Nov 19, 2007
- Dont mis understand..the thing is inappropriate mean that the solution given has nothing to do with the problem...The best thing you can do is re-install the drivers...
hi, CANON PIXMA MP160 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
eagle but i have to say the problem not fix i try what you said i disconected the cable then reconenect it but the problem still
what i have to do
thanks
Comments:
Nov 23, 2007
- hi i find solution i change my usb cable to original one i was have hp scaner before and i use that cable of hp scaner now my canon scan itis work 100%
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP160 All-In-One
product name:canon pixma 1980 Problem: the lamp flashes orange a few times after lighting green. so...
(More)
product name:canon pixma 1980 Problem: the lamp flashes orange a few times after lighting green. so the printer does not work. the printer only works when the green lamp flashes and persists.
