Question about Toshiba CN36G97 TV
Power light comes on with no picture or sound
I received a free TV yesterday. The only catch is that is doesn't work. I knew this when I got it. It is a Toshiba CN36G97. It was manufactured in April of 1998.
The previous owner owner tells me that they had NO problems with it until one day it just wouldn't come on any more. At that point they gave up on it and got a new TV. This one has been in there garage ever since.
The only things I know for sure is that the power light comes on at the same time a relay clicks over. There is a black box next to the relay that begins to get hot shortly after the relay clicks on. It is labeled as a resistor but looks like a relay. There are no obvious signs of overheating like smell or discoloration. The inside of the TV is VERY dusty so I think my first course of action will be to clean it out.
Any suggestions? I will be getting the service manual for this TV shortly as soon as I can find a reasonable place to get it from.
A little background on myself. I am a very experienced electronics tech I was in the Navy for 6 years troubleshooting and fixing aircraft electronics. The only thing stopping me here is that I don't have allot of TV experience. So most things I do will be guess work till I get a service manual. I am very aware of the voltages inside TV's and will take apropriate precautions.
I hope that is sufficient information for now. Basically I need to know what could be wrong and where to get a manual.
You can contact me at AngellXP@Gmail.com if you would like.
  • 1 more comment
  • Angell XP
    Angell XP Dec 04, 2007
    After further cleaning and inspection I found heat discoloration under two large diodes. Could they be bad or just normally hot? I couldn't see this under the blanket of dust that used to be in there.
  • Angell XP
    I actually got the manual from here already... I'll look trough it and see if I find a fix
  • Angell XP
    I will definitely check the diodes... I need a new battery in my multimeter... I use it too much I guess. :)
  • 56 Answers
I would think the diodes are bad. If there is definite discoloration somewhere the board as been hit?. What's funny is a lot of times dust can cause a lot of board failures from static electricty. But I assume when you receive the manual and have a meter you can test the loactions to see if the meter reads the proper volts?. Good luck!!!
Posted on Dec 04, 2007
    Sergeant:
    Champion:
  • 298 Answers
Here is a link for the service manual
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
Jul 10, 2015 | Yamaha HTR-5063 Receiver
I have a 50in Hisense 50K360G. The backlights come on, but no picture or sound. I replaced the main board and power supply and when that didn't work, I took it to a TV repair shop for a free
As far as the TV is now at any service center, it will be wiser to make it repaired there. Otherwise, you might have to spend more; sometimes will get it back in irreparable condition. I assume that, you will understand my words. Gopakumar Gopalan Google
Jan 20, 2015 | Hisense Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Tv repair
This happened to mine. It was a fuse that cost $3.42 but the service call was $200! If I knew how to do the freaking work I'd be rich!
Apr 09, 2007 | Toshiba 50HX70 50" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
