Question about Sony Ericsson W300 Cellular Phone
Cant get bluetooth set h-700 to work with phone
Cant get it to voice dial numbers
    Brigadier General:
  • 7,752 Answers
Re: cant get bluetooth set h-700 to work with phone
Make your BT visible on your phone and switch it on as well as the BT HS then try searching for it again.
Posted on Sep 20, 2008
0 characters
3 Points
How to use voice dialer (svoice) with bluetooth on galaxy s5
Corded headsets do not have Bluetooth. Do you have a Bluetooth headset (wireless) handy to test the Bluetooth function properly?
Nov 04, 2014 | Samsung Galaxy S5
I would like to know how to enable voice-dialing on my Samsung Intensity, I cant seem to figure it out....thanks
Voice dialing is enabled by default on the Intensity. All you have to do to use it (assuming you have at least one contact saved) is press the voice dialing button on the upper right side of the phone (near the camera) and on the menu that pops up, select Call (option #1). Then say the contact name you want to call -- for example, "Call Michael." You may have to confirm your selection, depending on your settings, and then the phone will dial the number you have saved for Michael.
Apr 17, 2010 | Samsung SCH-U450 Cell Phone
Cant set up voice mail
to set up voice mail on samsung S8300 dial 1750 - to deactivate voice moil dial 1760
Nov 21, 2009 | Samsung S8300 Ultra Touch platinium-red...
Can't Set up Voice Dialing
Are you saying "name dial" first? Name dial works only with the contacts in the PHONE contact list/ address book, otherwise you have to say "digit dial" and repeat the number.Also make sure you have gone to settings>personalize>voice dial set up, first.
Aug 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
How do i setup voice dialing to my bluetooth with my razor i have looked and looked
Settings>Headset>Voice Dial It isn't actually in the Bluetooth Settings. Hope this Helps =)
Jun 04, 2009 | Motorola Mobility RAZR V3
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
Voice activated dialing
Try going to Menu > Contacts > Voice Command
Apr 07, 2009 | LG RUMOR Cellular Phone
I need a user manual for thisSFK404 Bluetooth Visor Mount Handsfree Speaker but I cant seem to find one online so i could download it
didnt find any either too old but here is specs.
Model No: SFK404
Simply attach the Visor to the Sun Visor or any other suitable place, connect the Bluetooth hands free kit up with mobile and away you go.
Superb Quality simple Bluetooth Car Kit with Caller Id Display and Number Keypad for easier dialing.
* Talking Time : 5 Hours * Standby Time : 150 Hours
* MIC : -47+/-1.5 * Power Consumption : Max 250mA
* Carrier Frequency : 2400MHz to 2483.5MHz * Transmission Power : Typ.1.0 dBm
* Operating Temperature : -20 ~ 70? * Storage Temperature : -40 ~ 85?
* Speaker : 8W, Max 1.5W * Digital Volume Control
* AC/DC Adaptor : 5.0V / 1A * Car Charger : Out : 5.0V/800mA
* Battery : 3.6V, 950mA Li-ion Rechargeable NK8200 series compatible
Main Functions
*Superior noise suppression *LCD Display - Caller ID/Calling time
*Excellent echo cancellation *Support Making/Ending a call
*Super full duplex *Support Voice Dialing, Number Dial
Compatibility : Compatible with all Bluetooth mobile phones
Profile : Supports for both Headset & Handsfree Profile
Bluetooth v1.1 compliant
- Approvals : SIG, CE, FCC certified
Last Number Called
Voice Dialing ( Providing the Phone Supports the feature.
Number Dialing
Speed Dialing
Selct wether to answer, Reject and End Calls
Volume Control
Power On and Power Off Feature to reserve battery power.
Rechargable Battery
Battery Power Status
Incoming Caller Alert ( Visor will Play a Meldoy and the Led Display will Flash Blue )
Connect to Pc for firmware upgrades ( Cable Supplied )
Bulit in Speaker
Built in Microphone
Bulit in 4Mb Memory
Noise Suppression
Echo Cancellation
Supports both Headset and Car Kit Profiles ( Phone Dependant )
Transferring Audio Feature ( Both from Headset and Handset )
Standby 150 Hours ( Uses a Nokia 8210 Battery so you can have a spare battery or simply purchase any nokia phone model in car charger to charge from your car. )
Talk Time 5 Hours
1 Year Warranty
Compatable with all Bluetooth Enabled Mobile Phones.
Handset supporting headset profile
Ericsson: R520m / R520m, T39 / T39m / T39mcc, T68m / T68mc
Sony Ericsson: P800, T68,
Motorola: A803, T280i, TimePort 260C V1.1
Philips: Fisio 825/826
Samsung: X7700
Sky: IM6200
Handset supporting handsfree profile
Motorola: V525, V600
Nokia: 6310 / 6310i, 8910 / 8910i, 3650, 6230, 6600, n-Gage
Sony Ericsson: T68i / T68ie, T610, T613, T630, Z600
Siemens: S55, S56, SX1
Panasonic: X70
Jan 22, 2009 | Cell Phones
Adding voice to my phone book
press and hold the voice key, speak into the phone, release the voice key.
Oct 16, 2008 | Motorola Mobility RAZR V3
Unable to find Voice dial for bluetooth carkit
in your settings you have car setting try there first
Jan 04, 2008 | LG Prada KE850 Cellular Phone
Sony Ericsson W300 Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Jose Cada
Jose Cada
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
