Question about Compaq Armada E500 Notebook
Compaq armada e500 memory
I am trying to increase the memory on an old compaq armada e500 and I cannot find where the memory modules fit on the motherboard
  • 2 more comments
  • j2nellie Nov 14, 2007
    This particular laptop had two openings on the underside, one for the hard drive, and one for the processor. Memory modules are not visable.
    I do not have a product manual and compaq no longer supports this model online.
  • j2nellie Nov 17, 2007
    Yes, I did indeed find the modules under the keyboard. I was able to locate an online manual for the E500. Thank you very much for your help.
  • Anonymous Mar 01, 2008
    can you buy a new processor for these? i cant get the old one off, looks connected to the motherboard.
  • Karsin Mar 22, 2008
    How do I add new ram memory to a Compaq armada e500. I have the ram but need to know where the memory is located and how do I add a new one. Thanks
  • 55 Answers
Memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Posted on Nov 16, 2007
  • 4,889 Answers
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.compaq armada e500 memory - lapmem4.jpg compaq armada e500 memory - lapmem5.jpg
  6. Align the notch of the memory module with that of the memory slot and gentcompaq armada e500 memory - lapmem6.jpghe module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate thcompaq armada e500 memory - lapmem7.jpgwn flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power corcompaq armada e500 memory - 2f150f7.jpg up your computer system.
Step compaq armada e500 memory - cdbac1c.jpgg src="http://i.fixya.net/uploads/images/fe6458f.jpg" alt="fe6458f.jpg" clcompaq armada e500 memory - a24a0f2.jpg/>
Step 2:
Step 3:
cdbac1c.jpg compaq armada e500 memory - 9f27880.jpgp 4:
Step 4_1:
Step 5:
Step 6:
Step 7:
please rate it if it is solved..
Posted on Nov 13, 2007
  • eagle338
    eagle338 Nov 14, 2007
    From memory the old compaq laptop I saw had an access hatch in the
    middle of the rear face, just under where the monitor sits (up high).
    It is a small screw held cover (I think) which is very thin and it
    pulls out to reveal the mem socket.
    I don't have one anymore but that's what I remember about the mem upograde.
  • eagle338
    I found a link of the manual..just check it out..
    ftp://ftp.compaq.com/pub/supportinformation/forum/portables/1500user.pdf
    Problem Solver:
  • 12 Answers
The second solution does work, remove single screw under the base
which has the keyboard picture near it & unclip the keyboard by sliding 4 clips near the F keys. Remove keyboard and hey presto... the RAM is found!
Posted on Mar 02, 2010
I have a Armada e500.The memory is under the keyboard. There is a screw in the base and four tabs at the top of the keyboard. You can change the memory without disconnecting the KB.
PC133 doesn't work in mine.
Posted on Mar 02, 2008
I added 512mb ram to my armada e500 and screen will not come up
The new RAM module maybe incompatible with the existing RAM module.
I suggest you use the same make and speed as the original RAM module.
Feb 23, 2012 | Compaq Armada E500 Notebook
One long beep and one short beep, sounds out. Then is followed by a Read Only Memory I/O error, code 101. Just as I turn my Compaq Armada E500 on, that's what it does. Is there a fixable...
Looks like your RAM. Take it out, clean the contacts & replace. If it still does not work try another RAM module. I am sure its the RAM.
Jun 18, 2011 | Compaq Armada E500 Notebook
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
Added more ram but it's not working Compaq E500
what did you mean not working ?? didnt see the new Ram memory ?/ or didnt boot at all ....anyway ...when adding new ram memory ..first thing you do is to remove the Bios battery for to let bios on defaults and let it be able to read the new added unit ....second ...be sure the new added ram is compatible and in the same frequency ,then remove the battery like I said and in the last ...reinstall the operating system ....always look at the boot to see if the ram memory that is displayed is the same value with the one you know that actually is installed on the slots...it should work if this was just an option to make it faster ...and not a wild guess cause it use to have issues and didnt boot before...
Sep 10, 2009 | Compaq Armada E500 Notebook
Armada m3000 screen
you can mess around and try to fix it but on those old machines its really not worth it(I own 5 of these).Might I suggest the Armada M700 or the E500--e500 is what im on now and it runs better than a brand new dell or compaq)you might get a new screen on ebay for about 40 bucks. It might be a better idea to buy a new one and save the parts from your old one. You can get a new one for 70 bucks on ebay.
http://cgi.ebay.com/COMPAQ-ARMADA-M300-Intel-Pentium-3-LAPTOP_W0QQitemZ200297181300QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Jul 24, 2008 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Wondering about DVD
Hi Ladyret,I have a dvd rom fitted to my Armada 500,it is a DVD-ROM DRIVE DV-28E part No_1977067B-43 by Hewlett-Packard Company,hope this helps you.
Apr 08, 2008 | Compaq Armada E500 Notebook
Memory
you should first download this manual. i believe you need to remove the keyboard....which is fairly simple if you have a small screwdriver.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+E500+and+Armada+V300
Jan 22, 2008 | Compaq Armada E500 Notebook
SPEED OF LAPTOP
What is running in the background. If xp go here Stop Unnecessary Services Batch File .
Oct 10, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 - Increase Memory
Try one only 256 it should work now. You cannot use a 256 with a 64 it just will not work it is physically impossible. I know with some of those older models and Im picking yours is because you mention you were using 2x64. What you should have done was to buy two x 128 I am possitive your board can only handle 256mb of ram. Try the one only and if it works use that I dont think two of them will work not on that board?? Let me know ok. You might wanna clean your machine out with a software like this and its 30 days trial but has all features till it expires: http://www.tuneup.com. else if you dont want to take my advice on your laptop you can always go here: http://www.compaq.com
Sep 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
5,934 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
