Question about Acer Aspire 3610 Notebook
Power jack I need to know how to remove and replace the power jack on my acer aspire #1642. thank you,
  • Anonymous Dec 10, 2007
    the metal prong has fallen out so now i cant charge it. can i replace it with a new power jack?
  • makari Dec 24, 2007
    the metal prong came out and i was unable to put it back. now what?
    Problem Solver:
  • 16 Answers
Can i know the status of the jack? is it lose solder or what?if it is lose solder you need to dismantle your laptop.
Posted on Nov 26, 2007
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    No power at all, tried a new charger still no power and replaced the battery.
    Hi
    After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
    Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
    How do I replace a power cord jack in an Acer Aspire 5315. Removed all the screws,I think, but could not get it apart because of something in the middle holding it together. Could not find any more...
    Remove the memory, wifi, and hdd access panels. There is sure to be a hidden screw. Also remove the optical drive. Replacement power jacks are available on eBay from multiple sellers for $10-15. You need to completely disassemble the laptop and desolder the bad power jack and solder on a new one. I've found that reinforcing the power jack to the mobo with a hot glue gun prevents this repair from having to be done again in the future.
    Jun 24, 2010 | Acer Aspire 5315 Notebook
    My acer aspire 1642 is not turning on.....
    It can be1 of 4 things, the two most common issues is that the AC adapter is not powering up the unit, or the power connection on your notebook is broken. Either the Ac adapter will need replacing or your main board.
    second possibility, is that the battery is shorting out the notebook, try removing it and powering it up with the AC adapter to see if it turns on, if thats the case, purchase a new battery.
    lastly, it could be a bad power switch or mainboard, which will need to be sent in for repair as well.
    thanks
    May 29, 2010 | Computers & Internet
    Cahrging problems on Acer Aspire 1642
    u shud contact your vendor..and for more info contact http://tinyurl.com/m7ghqz
    Jun 16, 2009 | Acer Aspire 1642WLMi Notebook
    Information on Acer 1642 WLMI battery
    The replacement battery you mention is High capacity battery that will work with your laptop.
    186508APTA 14.8 Volt Li-ion Laptop Battery (works with Acer Aspire 1642WLMi).
    14.4/14.8V, 4400mAh
  • This battery only compatible with 14.4V and 14.8V version.
  • New 100% OEM compatible
  • Guaranteed to meet or exceed original specifications
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    May 15, 2009 | Acer Aspire 1642WLMi Notebook
    Bluetooth driver software
    This is the link to your bluetooth driver.
    http://global-download.acer.com/GDFiles%5CDriver/Bluetooth/Bluetooth_WIDCOMM_5.0.1.1400_XPx86.zip?acerid=633640461748020381&Step1=Notebook&Step2=Aspire&Step3=Aspire%201640&OS=X01&LC=en&SC=PA_6
    May 12, 2009 | Acer Extensa 5620-6119 Notebook
    Acer 1642 freezes and will not power down unless battery is remov
    sounds like a virus or malware, try this, go to spybot, search and destroy and download thier free program, also AVG. com, also free, and run them both in safe mode, also defrag your hard drive, start,programs, accesories, system tools, defrag, it may run several hours, let it a lone, first spybot, then avg, then defrag
    Jan 03, 2009 | Acer Aspire 3000 Notebook
    Acer Aspire 1642 WLM not showing with projector
    Try other F keys..other wise try Ctrl+alt+function key
    Dec 08, 2008 | Computers & Internet
    Acer Aspire 3610 Notebook Logo
    105 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
