Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The widescreen/ fullscreen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, superzoom, widescreen, fullscreen. Help, please.
  • petec35 Jan 27, 2008
    I have a Philips 42 inch plasma, and I have the same problem when using my apple TV on it.  Cannot find any solution.  Did you?
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Posted on May 05, 2008
  • c7carl Nov 28, 2010
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are!
I need my display set right 1/2inch to the right .
Posted on Sep 17, 2008
My philips lcd monitor 150S is failing me. I switch it on and then it shows and after few seconds the screen is black (meaning its off no picture) Then I off it and on again and then got picture for 2...
Check connections are good. Check pins in plug. Check with another monitor. Check with another cable.
If all tests are satisfactory then replace faulty monitor. End of life!
Jul 13, 2017 | Philips 150S (White) 15" LCD Monitor
My type pics etc looked squished horizontally
There is a fix have you tried auto configuring the monitor?
Apr 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
LCD TV screen goes black but sound remains.
i have the same exact tv and the same exact problem my problem started about 3 months after i bought it and since i didnt have the receipt couldnt do anything about it. i wish i could find a solution to this problem as well its so annoying.
Mar 28, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Sometimes when I change the settings profile from "User" to "Graphics," a black border appears on the screen and some of the viewing window is off the screen. Usually when I click the "Graphics" profile...
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
Flickers on start up and very slow going to normal viewing colors and lighting
FIXED: I took the advice to replace C110 and C111 with 1000uF 35V electrolytics (http://www.radioshack.com/product/index.jsp?productId=2102511). $3.18 and a pretty easy time prying open the case with a medium-small flathead screwdriver, disconnecting a few connectors, 4 silver screws (2 on the left & 2 on the right of the LCD), 2 black screws on the back of the metal case, 3 black and one brass screw on the PC board, and it works like new.
HINT: Be sure to insert your new capacitors correctly (positive and negative sides). The capacitor has + and - sides (the - side was marked on mine). The bottom of the PC board (where you apply solder) has a + marked on the positive side.
For the faint of heart: I am an inexperienced and HORRIBLE solderer and know close to nothing about capacitors, resistors, etc. So, if I can do it you can too!!!
Jul 28, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
1,669 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
