Question about Zenith XBV243 DVD Player/VCR
Tray will not open when I press button
I can hear a click, but it won't open to insert a disk....Any suggestions?
When I press the button it says "disc load", but it does not open. Thanks
Re: Tray will not open when I press button
It is most likely a worn drive belt. I have just taken mine apart and confirmed this. I will try replacing the belt with an o-ring as they are easy to find and readily available. If you are at all handy, removal of a few screws is all that is necessary. (Make sure unit is NOT plugged in when working on it.)
Posted on Jun 29, 2010
I have the exact same problem with my unit. I have been using it for months anyway. I'm too cheap to replace it. It just requires a little timing. Press the eject button, and the use your finger nail to gently LIFT the tray when it should be coming out. It will take some practice, but it WILL WORK. I can do it, but hubby cannot. It takes patience. {gravity must be making the door stick}
Posted on Dec 30, 2007
I had the same problem this weekend. I think it's the small rubber belt that moves the tray in and out and also lifts the tray to engage the spindle. It has stretched slightly. I am going to replace it and then see if it will work
Posted on Feb 18, 2008
  • 4,889 Answers
The tray will have a supporting element which lifts the tray up and ejects the drive..I think probably its worn out..You just need to replace shouldn't cost you much..
Posted on Nov 13, 2007
0 characters
3 Points
How do I remove a disc stuck in the tray?
1)See if there is a small hole at right or left side of disk inserting button.
2)Take a small pin and insert it into that hole untill it goes inside then your disk tray will open and now remove the disk.
May 15, 2015 | RCA Rtd3131 Component Dvd Players
My Sony dvp sr500h will not let me eject the disc and it displays Locked on the scree. How do I unlock it ?
The Blue Ray is just like a CD or DVD player.
If you have a disk in the unit and it will not eject through your my computer, find a paper clip and streghten it to about one inch.
On the face of the player, you will find a small hole. Insert the paper clip in the hole until you find the step. Bush forward and the door should open.
May 22, 2014 | DVD & Blu-Ray Players
Cannot open the disc tray
If you hear the motor trying to work then try to push the disk out by try holding the eject button for couple of seconds or press it and hold it couple of times real quick. If that works you need to leave disk in it in order to get the disc tray to keep ejecting I a have cdrom that works like this. If not take it apart and take out the cd you need and replace the disc tray with motor that works.
Nov 28, 2013 | Magnavox DV220MW9 DVD Player VCR
Samsung dvd R155 disk tray won't open/eject
1) try to clean the button with special contact cleaner spray
2) if this work, is o.k otherwise use the r. control and try to open the tray if work, is obvious the button was dirty. If doesnot work, you must the DVD player.
3) inspect any belt and replace, and lube any shaft +gear with small lubricant( vaseline) and replace any parts broken.Tight any wires connector very well and clean it.
4) if doesnot resolve the problem you must go the repair shopt TV for fix it.
God bless you
Jul 31, 2012 | DVD & Blu-Ray Players
DVD tray will not open on my Toshiba DVR620KU
Googled this for two days with no success! Finally, out of despiration I took the screwdriver to the top cover. (four screws in the back, and two screws on each side) Lifted up the rear section of the cover which the released the front for removal. The input pc board is right on top of the dvd tray so little could be seen, so I removed the screws and clips holding the pc board. Make sure that you you disconnect the power before doing this however. Once you have removed the three screws, (two of which have attached grounding clips) you will need to disconnect the HDMI cable which plugs into the back of the board if you had not already done so. Now carefully plug the unit back into ac power, and while holding the board in your hand careful not to allow it to touch anything,press the open button on the front of the unit, and as you move the board slightly while pressing the button, the tray mechanism will start to try to release. Press the button several times till the tray opens completely and stops. Now comes the tricky part: Unplug the AC power plug while the tray remains open. (Otherwise the tray may close again and you'll have to go through the wiggle routine again to get it to open) Once it is open, remove the DVD Disk if there is one in there. OK, so now if you have followed these instructions so far the tray is open and empty, and there is no power to the unit, you can begin reassembly. Put the three screws and two clips back into the PC board loosely at first till you have all three started, then proceed to tighten each one. Replug the cable into the back of the PC board and then replace the top cover and the screws following the same procedure. Plug the unit back into the AC receptacle, and turn the unit on, then press the open/close button, and the tray should open and close as normal. I think what caused the problem to begin with is that I had left a DVD disc in the player for an extended period of time in the start play mode, and it either jumbled the programming or damaged the disc. I have not tried to put the original disk back in the unit to find out! I want to use it for awhile first!
Jul 10, 2012 | Toshiba DVR620 DVD Recorder/VCR
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | DVD & Blu-Ray Players
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Does not play when disc entered nor when play is selected. (XD-E500KB)
Push in the plug connected to the "Video Out" jack on the rear of the Dvd to ensure it is connected firmly. Check the connection at the back of the TV as well.
Press the "Source" or "Input" button on the TV remote to verify the television's input is set to the DVD connection.
Press the "open/close" button on the front of the DVD to open the disc tray. Insert and test different DVDs to determine if the problem is with a specific disc, or if the player will not operate.
Eject the DVD tray and insert the DVD laser lens cleaner. Close the tray and wait a few seconds for the cleaning disc to load. Press "Play" on the front control panel to spin the disc through the cleaning cycle.
Remove the cleaning disc, insert a DVD and test playback operation. If the machine still will not play discs, the main receiver unit may require internal repairs best left to an experienced technician.
Feb 02, 2011 | Toshiba DVD & Blu-Ray Players
Region change to multi on govideo #DV1140
This might help gurantees...... take care...
GoVideo D2730
  1. Power up
  2. Wait for "No Disc" to bei displayed
  3. Immediately enter 7, 3, 8, 7, 9 (the last figure is for the region, 9 = multi-region)
GoVideo DV2150
  1. Open the disc tray
  2. Press 0, 5, 2, 0
  3. Press UP, DOWN, LEFT, RIGHT
  4. Press the button for the desired RC (0 = codefree)
  5. Close the disc tray
GoVideo DVP750 / DVP950
  2. Press 0, 1, 0, 6, 0
  3. Press the button for the desired RC (0 = codefree)
  4. Close the disc tray
GoVideo DVP850 / DVP853 / DVP855 / DVP860 / DVP865
  2. Press SETUP
  3. Highlight "Custom"
  4. Press 3, 3, 3, 3
  5. A menu should pop up (Secret)
  6. Select region (0 = region-free)
  7. Press ENTER
  8. Press SETUP
  9. Close the disc tray
GoVideo DVP1100 / DVP1165
  1. Turn on the player (without a disc inserted)
  2. Press PLAY 8x
  3. Press 0, 1, 0, 6, 0
  4. 9 should be displayed
  5. Press 9
GoVideo DVR4200 / DVR4250
  1. Change to dvd mode
  2. Insert a DVD and play it
  3. Press STOP
  4. Press PAUSE
  5. Press 3, 1, 4, 1, 5, 9
  6. Enter the region you want (0 = codefree)
  7. Press PAUSE
GoVideo R6640 / R6750
  1. region-free out of the box
GoVideo R6740
  1. Press SETUP
  2. Highlight "Exit"
  3. Enter 2, 9, 6, 0
  4. Press SETUP
GoVideo VR2945
  1. The disc tray has to be empty
  2. Press SETUP
  3. Go to the "System Info Screen"
  4. Enter 1, 1, 0, 1
  5. Enter the region (0 = multi-region)
  6. Press SETUP
GoVideo VR3840 / VR3845 / VR3930 / VR4940
  1. Press SETUP
  2. Scroll down to the lock symbol
  3. Keep Pressing 0 until it says "Congratulations region free!"
  4. Press RETURN
GoVideo D640, D645, DTH7000, DJ350, DP7240, DP8240, DP8440, DV1030, DV1130, DV1140, DV2130, DV3130, DV3140, DVR4000, DVR4100, DVR4175, DVR4300, DVR4400, DVR4550, DVR5000, DVR5100, GVP5850, GVP7811, R6530, R6540, VR1940, VR2940, VR5940
Jul 18, 2008 | GoVideo D645 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Zenith XBV243 DVD Player/VCR Logo
239 people viewed this question
Top Zenith DVD & Blu-Ray Players Experts
Jonathon summesfield
Are you a Zenith DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
