Cars & Trucks Logo
Bob Otis Posted on Mar 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for fuel system diagram
Smell fuel after the car is parked, both inside and around the car. Fuel lines and filter look good and free of cracks and leaks under the hood. I'm thinking it's in the vent system and/or to do with the carbon canister. Need a good diagram so I can be sure I'm not missing anything!
  • 1 more comment
  • Earl DaSquirrel
    Earl DaSquirrel Mar 26, 2015
    he gave you a generalized answer because you didn't state the year make model ~ agree it may be one of the evap system, but it should have thrown a trouble code on the car's ecu ecm pcm
  • Bob Otis Mar 26, 2015
    My apologies, when I made the post I was prompted for make, model, year, so I thought it would be visible. 1995 Toyota Corolla 1.6L
    Ya she's old, but clean, original and still runs great.
JOHN LAPIER
Level 3:
  • Cars & Trucks Master 2,602 Answers
  • Posted on Mar 26, 2015
JOHN LAPIER
Level 3:
Answers
2602
Questions
Helped
899751
Points
8635
Chances are its what is called the fuel pressure regulator is the problem.
These other systems have vents and valves and are disgined them selves .
The pressure regulator deals with the fuel injecters mainly back pressure feed back to the tank .
The vehicle will run OK but when you shut it off you smell gas vapor it has to get out .
    Thanks John, I guess that's possible, but that part releases fuel directly into the fuel return line and is routed back to the tank (closed system) no place for fumes to escape? Im familiar with the pressure regulator and on inspection it shows no signs of even the slightest external leak? I guess I'll replace it if I rule out everything else. Still would really like to see a diag of the vent system including the charcoal canister.
    PS, this car just passed GA Sate emissions test yesterday, so gas cap was just tested. The fuel smell has been on going for some time.
2answers
What causes a gas smell at the rear of a 1997 Ford Escort?
Leaky fuel lines or dead cylinder - gas/air mixture is un-burned and comes through exhaust
Smell gas while driving inside car
A leaking fuel line can be discovered by looking for gaspuddles under your car when parked. A fuel-injection line may also leak, causing you to notice the smell of gasfumes during and immediately after driving. A fuel-tank vent hose may also leak, causing unburned gas to exit your fuel system as vapor.24 Apr 2015
The Reasons a Car Smells Like Gas When Driving and While Parked ...
www.livestrong.com/.../169275-the-reasons-a-car-smells-like-gas-when-driving-and-whi... https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Smell+gas+while+driving+inside+car
1helpful
Fuel smell in 2011 Honda Fit...especially after idling
Check the air filter, may need replacing.
It's a good place to start, around the carb.
Look for fuel leaks.
Park car, put some newspaper under engine and leave over night. Check paper next day for fuel stains as indication for any sort of leak.
2helpful
2answers
What causes strong petrol smell in cabin of Ford Ka?
Most fuel smells inside the vehicle are the result of leaks in the fuel system. Have all fuel lines and injectors/seals inspected for leaks/seepage
1helpful
4answers
What would give out fuel smell ?
did you check to see if your gas cap is missing?
Dodge 1991 cummins 250 turbo diesel engine. Suddenly we get a fuel smell while driving. Yesterday the smell was like standing over the nozzle while filling the diesel tank. No leakage undernieth when...
Check your fuel lines, hoses, fuel filter, injector pipes, injectors, but most likely a worn seal on the front of the injection pump and fuel leaking out telltale/bleed hole.
Have a good poke around all the fuel system and you will eventually find it.
2answers
My car is smelling like gas.
From where? you haven't given enough info, but put a large piece of flattened cardboard under the car to see if any is leaking. You will then be able to see what general area it's coming from--if there is a leak.
It could be a fuel injector(s) or even something very simple. When is the last time you had a tune-up, including a new fuel filter? If it's been more than two years, it's overdue. That means new oil, oil filter, air filter, fuel filter, and spark plugs.If your car has a distributor, you should also replace the distributor cap and rotor (cap).
Try to locate a specific area where the smell is coming from. Breathing gas fumes is not healthy!
2helpful
2answers
3answers
Smells like gasoline in car when it's in idol
Check entire fuel system for leaks 99% of time wen you smell GAS.... there is a leak. So be very careful. Gasoline leaks can be very dangerous. If you had a tune up lately or changed a fuel filter that can be your problem because they are metal line then can be left loose accidentally. Check all fuel lines from fuel thank towards the engine compartment and you should be able to locate source of the smell. Good Luck and contact if you need more help. Thanks for using FIX YA
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
