With charge up battery max voltage from alternator should be 14.4 volt check if you got battery voltage on the alternator therminal in the back of your alternator if you got the same voltage as your battery your alternator is no good you need to change your alternator if you put 1 in dont forget your battery need to be full charge
SOURCE: Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
SOURCE: NEW ALTERNATOR, NEW BATTERY, CAR still dies and wont start
Check the main power fuse that goes to the alternator output. if the alternator went out it could have burnt this fuse also.
SOURCE: 2001 acura cl type s will crank but will not start
are some of your warning lights on your dash not lit when the key is turned to ON?? Such as engine, battery, abs, airbag light etc.
SOURCE: replaced alternator and battery is good but not charging
I found the problem YEAH. It was the fuse that is in the side of the fuse box under the hood, Its where the battery wire from the alternator connects thru a fuse to go to the battery, Its one hundred and something volt fuse. It took care of the problem instantly.... Thank you all for your replies...
SOURCE: car wont start got a starter but its the relay switch
STARTER RELAY IS UNDER THE HOOD AND UNDER THE DASH.IT COULD BE THE STARTER SOLENOID ON STARTER BAD.IT WILL CAUSE NO CRANKING PROBLEMS.
