I have a paperwhite and never seen it do that. I have seen it do some other odd stuff with a book though. Have you checked other books to see if they are ok? There may be a program error for that book. Back up to first page of a chapter to make it easier to find your place again. Delete the book from your kindle. Then look the book up on Cloud listing and try downloading again. You may have to go back to you account at Amazon and download from there. If it still does it's change thing contact support to see what they say about it.
Robert, links below should help, deleting photos.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Open Clean Master, tap phone boost, you should be able to see the game booster icon, tap it, now look for the 3 dots on the top right corner and tap, tap disable boost. If the folder is still on the main page, just long tap and drag it out to remove it.
The problem might be that your battery is too old. Rechargeable batteries have a limited number of charges that it can undergo.. usually between 300 and 500, before it starts to not hold much power anymore.. If it's not the battery,
I suggest you test the charger.
if you have a multimeter/voltmeter, unplug the charger from the wall socket and tablet. Set multimeter to measure Resistance/Ohms.. Touch one end of your meter cable to one of the charger pins(that you would otherwise stick into the wall socket) & the other end to the end you otherwise stick into the tablet.. all you're looking for is 'some' measurement... if you get a reading, test the other pin (wall socket end of the charger) .. if you get a reading again, then your charger should be fine.
Next look at your tablet, where you stick the charger into.. does anything seem loose/out of place? if no.. call the shop you bought it from an ask for assistance over the phone (typically shops offer advice freely over the phone)
go to setting (open 'setting' app) then click 'account' then 'add account', then follow the instruction until finish, everything should be back as before.
