2009 Toyota Camry XLE V6 Logo
S
Shawn Posted on Mar 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you disable the door chime?
Opening door when parking sets off the door chime, if you close the door and reopen it the chime stops. Depending on how long I am in the car after turning it off the chime sometimes doesn't even go off. It's so annoying and I just want to shut it off. It gives me an dash board notification if a door is ajar, I don't need the alarm as well.
Bill Boyd
Level 3:
Top Expert:
  • Toyota Master 53,816 Answers
  • Posted on Mar 25, 2015
Bill Boyd
Toyota Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11934455
Points
172802
Many drivers have dash lights to inform them that a door is open yet they still drive around and then complain about a knock some where in the back
I would check all the door sensors for adjustment and leave the alarm alone as , as annoying as it might be , it might let you know when a child has opened a door without your knowledge and save a life.
Testimonial: "Oh absolutely Bill. If I had children I wouldn't even ask this. But I do a lot of camping with my wife and listening to music from the car stereo means either the door is open and dinging or the window is open and the sound is muffled. I just want the ding to stop. I get a notification on the dashboard that a door is open and it tells me exactly which one and blinks. You can't miss it. I don't need the ding too. You can easily disable the seatbelt warning which I totally think you shouldn't be able too, so why not the door chime???"
  • Bill Boyd Mar 25, 2015
    find the door chime and it should have wires to it . try pulling one wire off a terminal
How do we get a 2006 Uplander to stop chiming?
What is it chiming ? Chimes for different reasons , headlamps on , seat belt not buckled , etc.... What warning light is lit on the instrument cluster ? if any . seat belt , air bag's etc...
Audible Warnings Description and Operation
The audible warnings alert the driver of a system concern or a critical vehicle condition. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
Fasten Safety Belt Warning
The inflatable restraint sensing and diagnostic module (SDM) activates the fasten safety belt audible warning for 5-8 seconds. The fasten safety belt warning sounds and the fasten seat belt indicator illuminates when the following occurs:
• The ignition switch is in RUN, BULB TEST, or START position.
• The SDM detects that the driver's seat belt is not buckled (signal is low).
If the seat belt is buckled before the ignition is in RUN, BULB TEST, or START position, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops.
Key-In-Ignition Warning
The instrument panel cluster (IPC) activates the key-in-ignition audible warning. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is in OFF, LOCK, or ACCY position.
• The body control module (BCM) determines that the driver's door is open (signal is low).
• The BCM determines that the key-in-ignition switch is closed (signal is low).
Lights On Warning
The instrument panel cluster (IPC) activates the lights on audible warning. The lights on warning sounds when the following occurs:
• The key is not in the ignition.
• The body control module (BCM) determines that the drivers door is open (signal is low).
• The BCM determines that the headlamp switch is in the park or head position.
Rear Parking Assist
The rear object sensor control module activates the audible warning. The audible warning sounds whenever any of the indicators are illuminated on the rear parking assist display. For a description of the rear parking assist system refer to Object Detection Description and Operation.
Turn Signal Reminder
The instrument panel cluster (IPC) sounds the turn signal reminder once per each flash of the turn signal lamps when:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit (left or right turn).
• The vehicle has traveled a distance of 1.2 km (0.75 mi) by counting pulses on the vehicle speed input circuit.
The IPC turns off the turn signal reminder when either the ignition switch is turned to the LOCK position or to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits (left turn or right turn).
Additional Chimes
The following chimes will turn on when an associated indicator turns on in the instrument panel cluster (IPC):
• Low Fuel Indicator
• Low Oil Pressure Indicator
• OVER SPEED indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation.
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console.
Your have a problem with one of these systems , your best bet , take it to a qualified repair shop. They would do diagnostic's to find the problem .
Do any indicators illuminate when the chime sounds?
Go to Symptoms - Instrument Panel, Gages and Console
Go to Step 3
Turn the ignition OFF.
Remove the key from the ignition.
Turn the headlamp switch to OFF.
Close all of the vehicle doors.
Open one or more of the vehicle doors
Does the chime sound at all times regardless if the doors are open or closed?
Go to Step 15
Go to Step 4
With a scan tool, observe the LF Door Ajar Switch parameter and the RF Door Ajar Switch parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Door Ajar Switch parameters display Door Closed?
With a scan tool, observe the Left Rear Door Ajar Sw. parameter and the Right Rear Door Sw. parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Rear Door Switch parameters display Closed?
This is a 21 step diagnostic trouble shooting flow chart .
2answers
Disable seatbelt chimes,will not go off, since driver door been replaced.
Sounds like the door switch is not switching or not connected. Sometimes the switch is external in the door jamb/closing area, sometimes it is part of the door catch. Maybe check if the door light on the dash stays on, also if the interior light works on door setting.
1helpful
How can I disable the door chime which is triggered every time I open the Drivers door of of my 1996 Lincoln Continental?
Its sensing that there is a key in the ignition. You have to replace the switch in the ignition cylinder that senses a key is inserted. Or alternatively access a wiring diagram and cut the wire from the key sensor to eliminate it.
2003 ford escape chimes when driving
First be sure the turn signal is off, sometimes if you drive for some time with it on it will chime. Does the chime also continue from the time the car starts, even when it's not moving? If so, start the car in park, open a door at a time and press the switch on the door jam, if chime stops, the switch should be adjusted or replaced, if not continue with each door, one at a time being sure all the other doors are closed.
1helpful
2answers
Had the battery changed in 2007 nissan murano and now the chimes don't ring and the drivers doesn't automatically move back when opening the drivers door. How do I reset these?:
Disconnecting the battery erases stored memory,after you connect the battery put the key in the ignition cylinder and turn the driver door switch on(open) and off (closed), on (open),the entry,exist function then becomes complete, and the return operation can be operated,
1helpful
I own a 2007 montana and had it for 1 month now ..It keeps making a ding ding ding chime while driving ..The passengers rear door is automatic and when I press the button it makes the same noise but when...
1. Turn off the overhead over-ride switch. Drive again. Do the chimes stop? If yes, the door is not closing properly due to the door contacts. Clean them yourself or have them serviced.
2. If the chimes did not stop in step 1. above, it's not likely the door but rather something else.
3. Chimes occur for many reasons. Suggest checking - a. are the rear back-up warning sensors blocked/dirty? b. any other lights on the dash like oil, abs, airbag, etc? c. passenger side airbag disabled - something heavy placed in passenger seat?
In my experience, it's the automatic door contacts. We have a long history of problems with these auto doors, that are still not resolved. problems all throughout the warranty period, and now into the extended warranty period. We must unite and get GM to resolve the quality of these doors. My next step (next incident) is going to be to have the dealership inspect the entire wiring system.
Key on engine running trouble code 55
Warning Chime Systems The generic electronic module (GEM) will sound the following warnings:
  • key-in-ignition warning
  • safety belt warning
  • headlamp switch ON warning
  • door ajar warning
Headlamp Switch On Warning The generic electronic module (GEM) sounds when the driver door is opened while the headlamp switch (11654) is in the PARK or HEAD position, and continues to sound at a rate of 4 chimes per second until the headlamp switch is turned off or the driver door is closed.
  • When the headlamp switch is in the PARK or HEAD position, power is supplied through Circuit 293 (O/R) to the GEM.
  • When the driver door is open, the driver door open warning lamp switch (10B997)is closed and ground is supplied to the generic electronic module (GEM).
A delayed headlamps on repetitive chime will sound for a period of three seconds beginning twenty seconds after the key is turned to OFF, LOCK or ACC, the headlamp switch is in the PARK or HEAD position, and the driver door is closed. Delayed headlamps on is terminated by opening and closing the driver door again.
Door/Liftgate Ajar Warning The door/liftgate ajar warning functions as follows:
  • The generic electronic module (GEM) sounds a warning tone for one second when any vehicle door, liftgate window or the liftgate is ajar without any other door already open and the ignition switch is in the RUN position.
  • Power is then supplied through Circuit 627 (BK/O) to the door ajar warning indicator lamp which remains illuminated until all doors are closed or the ignition switch is no longer in the RUN position.
Key-in-Ignition Warning The generic electronic module (GEM) sounds when the LH front door is opened with the key in the ignition switch and continues to sound until the key is removed or the door is closed.
  • When the key is in the ignition switch, the ignition key warning switch terminal and wire (11A128) is closed and ground is supplied through Circuit 158 (BK/PK) to the generic electronic module (GEM).
  • When the LH front door is open, the LH front door open warning lamp switch (10B997) closes and ground is supplied through Circuit 57 (BK) to the generic electronic module (GEM).
Safety Belt Warning When the ignition switch is turned to RUN or START from the OFF or ACC position and remains in RUN or START, the chime will sound for six seconds or until the safety belt is buckled. The safety belt warning indicator lamp (10C859) will turn on for 60 seconds, or until the LH front safety belt is fastened. Both the chime and lamp activate at the same time. If the safety belt is buckled when the ignition key is turned to RUN or START from OFF or ACC, the lamp will prove out for two seconds, but chime will not be activated. Any time the key is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
