Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
No picture with Vertical bars across screen
The sound is ok. The vertical bars (25 about one inch wide) cover the screen. Behind the bars some movement. The menu behind the bars is half off the right side of the screen and the letters look reversed.
It sounds like one of the flexes on the LCD cube has either become unplugged/ loose, (there is a gate that locks the flex in connector on the DMD board), or flex damaged. Has the TV recently been moved or strongly jarred?
Posted on Mar 21, 2008
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Inch wide vertical white band on my Imac screen?
If the white band appears right from start up, the display needs to be replaced, if it comes on after it starts, it is most likely a software problem.
Feb 16, 2009 | Apple iMac G5 Desktop
Multi coloured vertical stripes on plasma screen
With half of the screen working, and with a Plasma tv. I will look at the driver board as being bad. Take the back cover off, the driver pcb will be at the top or bottom of the set. They are only about 2 inches tall and will cover most of the lenth of the set (2 boards that run end to end). The board that is on the side of the tv that is bad is the bad board. Replace that board or have a tech replace it.
Nov 15, 2008 | LG 42PX5D 42 in. Plasma HDTV
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Wide white horizontal bar
do actual replacement of all electrolytic capacitor surrounding from the vertical ic.
Jan 19, 2008 | Sanyo DS24425 24" TV
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
