Music Logo
A
Anonymous Posted on Mar 25, 2015
Is drake the best rapper? if not prove it
Drake is the best!
Frederick Electrick
Level 3:
Master:
  • Master 350 Answers
  • Posted on Mar 25, 2015
Frederick Electrick
Master
Level 3:
Master:
Answers
350
Questions
Helped
107195
Points
1344
No
listen to this....
Newcleus Jam On It Official Video HD
rhodesworks
Level 3:
Top Expert:
  • Music Master 3,159 Answers
rhodesworks
Music Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
561482
Points
331463
There is no such thing as a best rapper.
PMP 4000. Porneste sursa putin iar apoi dispare tensiunea de alimentare a amplificatoarelor
That appears to be Italian in our English speaking website
PMP 4000. Start the source a little and then the supply voltage of the amplifiers disappears
https://translate.google.ca/?hl=en&tab=TT&sl=auto&tl=en&text=PMP%204000.%20Porneste%20sursa%20putin%20iar%20apoi%20dispare%20tensiunea%20de%20alimentare%20a%20amplificatoarelor&op=translate
Only Behringer can fix
Service - Behringer
www.behringer.com > service
SHOULD THE SOFTWARE PROVE DEFECTIVE, YOU ASSUME THE ENTIRE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
and
https://www.behringer.com/product.html?modelCode=P0A8N
Trying to find out the year my Goya guitar was made it's serial no is 890ooooo1 and what's it all mean
A couple of Goya links that may prove useful
http://goyaguitars.tripod.com/index1.htm
http://goyaguitars.tripod.com/goya_info.htm
Your 8-9 digit serials (89000001 or 890000001) makes no sense ... too many numbers
My digital effects does not work at all. It makes a noise only on the distortion setting and all it does then is hiss. Any ideas
Make sure your power supply is doing its job. check output reading w/ a ohm meter and compare it to the info on the back of the supply. i am assuming your using tje recommended power supply. if this does not prove to be the cause. you may have send it out for diagnostics and most times it's just cheaper to buy new. good luck
Sep 15, 2014 • Music
Fender fm212 cutting out
Put you hand into the speaker and try to wiggle it and see if it makes sound in a certain position and not in others. This will prove whether or not the speaker has a broken winding on the voice coil. I would definitely verify the speaker condition before thinking the amp is the problem.
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
1helpful
Hi I have a Digitech RP 300 Modeling Guitar Processor that lights up and will play the metronome tik but will not output the guitar, the guitar input is dead or semes to be. can any one help. thanks...
The metronome is built in software, but it proves that your output is working fine. That's good.
Try changing your patch cable from guitar>pedal. if that doesn't fix it, grab a screwdriver.
Open the pedal and check the input port - is there any bent pieces or blockages preventing the cable from contacting what it needs to? Is the solder broken, cracked, or missing? Are both contact points firm and in place?
May 11, 2011 • Music
3helpful
2answers
When standby is turned on a loud humm then fuse blows
Replace diodes CR6 through CR9 and test C31 and C33 for short. If all OK and fuse still blows, remove the power tubes and test. Hopefully you do not have a transformer short.
To save fuses, put a 150 watt light bulb in series to act as a reseting fuse while testing.
My amp breaks up too much and sounds messy. I changed the tubes and resistors and it helped a little but didn't solve the problem. Could it be my speaker?
colearthur16, Only a slight chance of problem with your speaker. You will need to prove that all stages of amplification of the audio signal from input to output are not being driven into distortion (clipping) because of a bad DC power supply rail to the low level amplifiers or the high power "final" output amp! To prove this, you will need the help of an electronics technician who has access to a variable audio signal generator (amplitude and frequency) and a cheap 5 to 20 megahertz oscilloscope to view the amplified waveforms of the amplifier stages in the Fender Amp. Remember the following statement for the rest of your life!!! "All musicians who use electronic amplification to play musicial notes through speakers should have between 4 and 8 hours of classroom instruction on how typical amplifiers (tube and solid state) operate and how to troubleshoot them when they fail to perform to rated specifications!!!"
Cole, have the Fender amplifier (not the speaker) tested by a qualified technician to prove amp is not at fault!!! 12fixlouie
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
