Washing machine does not drain
Hi i think my machine is blocked, the water is not draining...can someone please help me
  • 1 more comment
  • Anonymous Dec 23, 2007
    washer wont drain
  • ghood100403 Jun 18, 2008
    My washer will not drain.
    When the machine reaches the drain cycle the control knob goes through the cycle but the pump doesn't seem to be kicking on. It used to be sporadic, and if you open and closed the lid it would kick into the drain cycle, but now I get nothing. It sounds like the pump is trying to kick in because you can hear other noises besides the ticking of the timer/control knob.
    When the machine reaches the drain cycle the control knob goes through the cycle but the pump doesn't seem to be kicking on. It used to be sporadic, and if you open and closed the lid it would kick into the drain cycle, but now I get nothing. It sounds like the pump is trying to kick in because you can hear other noises besides the ticking of the timer/control knob - It is a Danby DWM99W top load washer.
  • 139 Answers
What make and model machine is it
Posted on Nov 13, 2007
Washer is full of water. drain is blocked with hair or lint i believe. washed some nasty stuff. wont drain. how do i clear the blockage? i think may be blocked inside washer. drain hose is very narrow...
If you can get a garden type water hose near there, try to carefully use it to blow the water backwards through the drain hose. Put the hose up to the drain hose end and wrap a rag tightly around it and turn the water slowley. This may free up any debris from the hose and pump. If anything comes out,clean it out of the tub before you turn it back on.
Sep 02, 2011 | Kenmore 2.1 cu. ft. Portable Top Load...
My smart drive model LW015-K top load washer won't drain the water, I think the draining mechanism is blocked but Im not sure. I forwarded to spin cycle to force drain but it just makes a buzzing sound...
sounds like blocked or the pump is shorting out, do not keep using it otherwise the pump can short your board out, get a repairman unless your a handyman
Sep 02, 2017 | Washing Machines
Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Apr 08, 2010 | LG Washing Machines
The washing machine won't drain the water, the washing itself looks covered in fluff so now thinking system is blocked with fluff oh crikey what can I do please oh please Hotpoint aquarius WM62
drain screen or hose is most likely clogged. That is usually the case when they don't drain. Newer machines are really tempermental this way.
Jul 10, 2009 | Washing Machines
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Apr 23, 2009 | Electrolux Washing Machines
Have a beko washing machine and the water will not drain! Any ideas PLEASE
hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
Jan 29, 2009 | Beko 24 in. D3421F Free-standing...
Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Jul 28, 2008 | Zanussi FC1200W Front Load Washer
Hotpoint WMA35 - water will not empty and will not spin
Hi Debbie
Yes your machine will not spin if the water cannot drain... I do not have the machine in front of me but I would presume to think that you have a blockage in the water pump (or drain pump)
There is a normally a small pvc or plastic filter just before the pump and this would stop most big things entering the pump.. if not there could be a coin or button stuck in your pumps impeller.
Unfortunately if you are not technically inclined you will find it hard to access and open the pump otherwise just open the back plate on the machine (after removing the power socket from the wall) the pump is located at the bottom left and fairly easy to remove and open the plastic casing.
If this does not solve your problem please give more info........
Feb 20, 2008 | Hotpoint WMA35 Front Load Washer
Kenmore washer
Lori, first check the lid switch, if it's broken, it won't spin or drain. Put it into spin and hold the switch down, see if it drains. Check that first...Catriver..post back.
Feb 23, 2007 | Kenmore 20722
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
