Question about Palm i705 Handheld
Will not turn on or charge
All of a sudden my i705 quit working...will not charge, will not turn on or reset? Any ideas
0 characters
1 Points
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
My Plam Zire 21 handheld has worked fine; suddenly it will not turn on, or at least the screen remains dark. I have tried re-charging the battery, and resetting the device, but to no avail. Any other...
It is possible that the battery has lost it's skill. If you can plug it in, either by usb to a computer or through the power supply, and the screen shows it is a goner.
The link below is for the palm zire m150 if your interested in replacing the battery yourself. The zire 21 is similar to that model so it's pretty much universal.
Apr 06, 2010 | Palm Zire 21 Handheld
My Blackberry suddenly quite working and would not turn off so I pulled the battery and then tried again but all I get is a red light for 10 seconds then nothing.
I left the battery out all night and then reinserted it and plugged the phone into the charger to charge up the battery. As soon as the charger was connected the Blackberry it fired up normally. Go figure!
Jan 30, 2010 | RIM BlackBerry Pearl 8100
I hooked my palm
Slow charge for 8 hours
Jul 31, 2009 | Palm i705 Handheld
Cannot turn Palm TX on after listening to music. Button protection was set to "on". Now I cannot turn it on with any buttons. Tried charging with wall charger overnight. The case normally gets warm on...
Something similar happened to me. I finally gave up on my wall charger and tried connecting my PDA to my computer and pressed reset button several times. I left it connected overnight and It was working by the next morning. My guess is that my battery was completely drained and my wall charger quit working.
Jun 28, 2009 | Palm TX Handheld
My palm pilot m515 wont turn on or charge
try turning it on while its on the charger .. if that works then you might need a new battery .. if it doesnt then do a "reset" ... unscrew the top off the stylus and use it to push the reset button on the back (top center) ... if that doesnt get it going then you can do a hard reset but that will erase all your information (like telephone numbers and such) ... you do a hard reset by holding down the on/off button while pushing the reset .. if it works on the charger but quits when on battery then you need a new battery ..
Jun 27, 2009 | Palm m515 Handheld
Palm i705 won't turn on
are you certain that the belkin universal charger, is compatable with the palm ?
if any single cable, is wired differently. this could have damaged the palm.
try a hard-reset using your palms user manual.
this varies between pdas, usually comprising of either a reset hole, at the bottom of the palm, or underneath the battery on certain models.
i,d suggest obtaining the correct charger/usb cable.
as you may cause damage to the unit. most new devices have a battery fitted, but does not necessarily mean it,s charged.
Hope this helps, please rate the solution.
Mike @ compurepair.
Nov 06, 2008 | Palm i705 Handheld
Reset button won't work on dell axim x51v
to wlumbria... hey listenup... if ur connecting ur pocket pc to the cradle it is not only used for the flow of data bt it also charges ur pocket pc... bt the chargin is quite slow  it will keep on showing  the red lite as compare to an charger it will charge fast and the red lite will turn green... so wht i suggest charge it with a charger not with a cradel if stil it doesnt wrk try changing the battery...!!!
Aug 21, 2008 | PDAs
Open Questions:
Palm i705 Handheld Logo
16 people viewed this question
Top Palm PDAs Experts
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
