Gigabyte ga-g31mx-s2 beep codes not consistent
I bought a new GB mobo (ga-g31mx-s2) and everything worked fine till I updated the chipset drivers - since then BIOS has been giving inconsistent beep codes on start-up... Sometimes I just get the single beep that means everything's working, sometimes I get the code telling me my keyboard isn't detected (even though it is - works just fine), sometimes the code telling me my graphics card isn't installed properly (but it is - works great), sometimes I just get one long unending beep that won't go away till I turn of the PC. I've talked w/Gigabyte's tech support and they told me to test it without peripherals and with only one stick of RAM - did that and still had the problem (tested it in steps - one stick of RAM, then two, then added a peripheral such as keyboard, then mouse, then one drive then another, then ethernet, and so on...). I've tried both the latest drivers and the original drivers that came w/the mobo (on disc), I've flashed the BIOS, I've tried everything I can think of. Gigabyte is telling me I'll just have to RMA it and get a replacement, but that would leave me without a PC for far too long. If you have any experience with this sort of thing, I'd greatly appreciate teh help!
  • 1 more comment
  • Anonymous Jan 22, 2008
    When booting up, system hangs after showing the CPU Config., where u have to press "DEL" for setup etc.,. This is inconsistent as after a few re-starts it will pass that stage and check IDE drives. After rebooting it will start the hanging process again. I am stumped!! I also cannot afford to be without my PC for a long time. Pls help.
  • Anonymous Jan 02, 2009
    I had the same issue.
  • Anonymous Feb 25, 2009
  • 883 Answers
Try this: open the system restore utility (built-in with win XP if you have this OS), then select a date before you updated chipset drivers. Everything should come back the way it really is a WINDOWS problem that is trying to talk to BIOS but can't for some reason.
Posted on Nov 14, 2007
Having same problem loads up too xp sign on then monitor is blanki can hear xp loading, also just before it went down i had a concern with intel chip set not digitly signed so windows was saying problem with the driver for graphics card intel/chipset, and does not work with my pci express card. second day nice board?
Posted on Dec 18, 2007
Check your cpu fan. See if it is spinning during POST.
Posted on Nov 23, 2007
Computer restarts over and over @ bios screen
you may try resetting bios by taking off the small battery on motherboard for few sec, also if you got manual for your motherboard there may be way to reset bios sticking together 2 pins for couple of sec. Is radiator fan working? if no there's solution.
Feb 11, 2014 | Gigabyte GA-M68MT-S2, AM3, nForce 630a,...
Just ordered this board and another geforce 9500gt problem is i dont think i will be able to run both the video cards in this mobo i was reading manuall and it says an ati hybrid? GA-890GPA-UD3H is mobo...
It will run just fine, just make sure it's configured correctly in the BIOS - you will have to manually disable the onboard video card and activate the SLI configuration ; don't forget to install the bridge.
Feb 01, 2011 | Gigabyte GA890GPAUD3H AM3 Socket 890GX ...
MSI mobo with INTEL chipset won't recognize ATI card
well i know the problem so well, driver installs fine and when system runs it wont load the driver.. i had the same problem and the solution is so easy, just update the BIOS for ur mobo. and after new BIOS when system boots u will be surprised
Dec 25, 2009 | Computers & Internet
I have GA945GCM MOBO. While booting it gives continuous beep. If any keyboard key is pressed it stops. The keyboard spacebar key is not functioning. After boot in windows XP, the keyboard problem (spacebar...
Hi shreepad,
Those sound like you have a bad memory chip DRAM or it may not be seated correctly. The beep code of 1 long beep, also indicates a bad memory chip. If you have two or more, take one out and until you find the one that's bad. Then replace it.
Good Luck
Nov 24, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
Ga-k8ns pro motherboard/ pc self build
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Mar 30, 2008 | Computers & Internet
ADA3700AEP5AP 3700 Clawhammer wont boot
I believe that it should work with that chip. If you have the manual for the MoBo try resetting the cmos on the board. That should put every thing back to its defaults. It is posable that it is trying to run it at the wrong voltage.
Feb 29, 2008 | Gigabyte GA-K8VT800 Motherboard
Not booting up.
can you get into the bios?
Nov 01, 2007 | Gigabyte GA-K8NF-9 (890552602964)...
GA-G31MX-S2 Motherboard
try changing your CMOS Battery the CR2032...
Oct 28, 2007 | Intel Motherboard
Computers & Internet Logo
829 people viewed this question
David Payne
David Payne
